Onan CCK Fuel Pump
this thread has 12 replies and has been viewed 5631 times
Old 01-05-2010, 01:14:03 AM
Jscatt Jscatt is offline
Default Onan CCK Fuel Pump
Hello!
I just got a Onan RV generator model 4.0 cck-1R/6000P. It is missing the fuel pump and was if it could be replaced by anything except the 200+ dollar oem pump. Thanks!!
Old 01-05-2010, 09:40:58 AM
K D Redd K D Redd is offline
Default Re: Onan CCK Fuel Pump
Go to a local auto parts store and buy a LOW PRESSURE ( 2 to 4 PSI) 12 volt electric fuel pump.
Kent
Old 01-05-2010, 10:26:20 AM
Exclamation Re: Onan CCK Fuel Pump
Block off the old pump mount with a steel or aluminum plate to seal the block!
Old 01-05-2010, 11:21:33 AM
Dave Edmonds's Avatar
Dave Edmonds Dave Edmonds is offline
Pumps can occasionally be found on Ebay, but they are rare. The advice provided above worked for me. I used a Mr. Gasket 42-S pump (2-3.5 psi) from Advance Auto Parts for about $40.00 Works great! (Don't get the 12-S model; it makes too much pressure).
Dave Edmonds
Old 01-05-2010, 11:35:23 AM
Thanks for the advice! I'm sure I'll be back with more questions!
Old 01-05-2010, 07:44:34 PM
bobbyz72 bobbyz72 is offline
you say you just got the generator. What do you plan to do with it? If you plan to make a regular generator out of it as it did you could just mount the take above the generator and you dont need a fuel pump.
Old 01-05-2010, 07:47:35 PM
Bobbyz72 is correct. The carb can be gravity-fed if you choose to do so. The purpose of the fuel pump is to get the fuel from the tank to the carb, not to "pressurize" anything.
Dave Edmonds
Old 01-05-2010, 07:54:25 PM
Ben Cowan Ben Cowan is offline
Yep, don't have to have it but, I've got mine on a small trailer and run it with 5 gallon fuel tanks that I place on the ground beside the unit. You might consider placing one of the outboard motor fuel primer bulbs between your tank and the fuel pump. This certainly makes it easier to prime and start the unit. I personally like to run my unit completely out of fuel and leave my carb dry when storing the generator. I also used one of the Mr. Gasket pumps on my 4.0 cck generator. No problems, works just fine. Ben
Old 01-06-2010, 12:51:10 AM
richard.bessey richard.bessey is offline
Kent
2nd on ordering a new automotive pump. I did, but the pump put out too much pressure so I had to add a regulator, works like a champ.
Old 01-06-2010, 09:18:46 AM
You have to be sure you get a LOW PRESSURE one. One local auto part store where I shop, In the Performance/Hot Rod Area has two small square electric fuel pump. The look identical except for color of the decals on the clear plastic box. One is 4 to 7 psi. The other is in the 2 to 4 psi range. You have to watch what you pick-up.
Kent
Old 01-06-2010, 01:35:21 PM
Billy J Shafer's Avatar
The only thing wrong with gravity fed system. If the seat gets trash under it you will drain the gas tank into places you do not want gas to go. Have a shut off valve on the tank.
Old 01-06-2010, 02:31:54 PM
GOOD point, Billy. I filled up my CCK in the wintertime (has a 6-gallon boat tank and mechanical fuel pump), and closed the vent on the tank. When the gasoline heated up in the spring, it expanded, went through the fuel pump valves, found a less-than-optimum-sealing needle and seat, and filled the crankcase with gasoline! Same thing happened to my son, with a 71 Fiat when he had the fuel tank out of it and was running the engine on a boat tank elevated above the carburetor. Engines do not like having their crankcases filled with gasoline! (I guess the only good thing is that it gets some of the sludge out!)
Dave Edmonds
Old 01-11-2010, 10:35:05 PM
Well, I purchased the low pressure fuel pump and installed it and it works great! I never thought of the gravity feed idea, guess I should have waited for more replies! Anyway, thanks for all the advice!!
Onan 2.5aj-3p/1k Fuel Pump 2cubs2cases Onan Generators 0 08-04-2009 07:49:26 PM
Onan cck - fuel pump richard.bessey Onan Generators 11 08-04-2009 02:11:53 AM
Can you run a BF Series Onan w/o Fuel Pump GlennB Onan Generators 8 04-01-2007 04:53:36 PM
onan fuel pump Bob S Onan Generators 2 02-18-2006 02:04:58 PM
Fuel Pump for Onan CK-S/259M desighitter Onan Generators 0 02-04-2005 11:59:01 PM
