Kohler Generators
Kohler PDFs Available
this thread has 149 replies and has been viewed 41896 times
Old 01-30-2010, 09:18:44 PM
n5sqy n5sqy is offline
Default Kohler PDFs Available
For the Kohler guys, I have available in PDF format if you need them:
Kohler 4.5ckm21-rv operator-install TP5005
Kohler 4.5ckm21-rv service manual TP5206
Kohler 4-5CKM Service Manual TP5394 12-94a
Kohler 4-5KM Operation Manual TP5393 04-92
Kohler 4-5KM Operation Manual TP5393 09-93
Kohler 4CM21-Owners-Manual TP1040-527
Kohler 5.5-7CM21-RV Parts TP1184 05-87
Kohler 20RCOP Armature Service Manual TP5249 4-88
Kohler K-Series-Engine-Owners-Manual TP1436-C
Kohler K-Series-Engine-Service TP2379 11-92
Kohler Marine Installers checklistTP5723 12-94a
Kohler Spec Number Wiring Diagram Cross-Ref ES913 04-83a
Kohler 10-12CCE CEZ Operation Manual TP5977
Just let me know and I can email them to you.
Rob
The Following User Says Thank You to n5sqy For This Post:
Old 02-02-2010, 01:06:35 PM
louster louster is offline
Default Re: Kohler PDFs Available
Hi Rob,
I have a KE 2 Kohler generator, I would like any information you could send me. Thank you . lou5050@hotmail.com
Old 02-08-2010, 07:50:08 PM
Mike G Mike G is offline
Rob,
Do any of those include info on the L600 engine?
Thanks!
Mike
Old 02-15-2010, 04:20:21 PM
RVHMS1 RVHMS1 is offline
Ha Rob I have a 4CM21 Kohler genset on a L654 engine. It is the old relay lodgic. The controller # is C-245895B I am will to pay for them.
Old 02-17-2010, 11:52:21 AM
david e. sundeen david e. sundeen is offline
am in need of L600 kohler engine info. thanks dave E:mail babyheavin1@bellsouth.net
Old 02-17-2010, 03:40:01 PM
rodpusher rodpusher is offline
Hello do you have a controller wiring diagram for a model 6.5c61 Thank you rodpusher@yahoo.com
Old 02-20-2010, 02:52:07 PM
dkirksey dkirksey is offline
Rob
I would really appreciate a service manual PDF for my 4.5ckm21-rv
Help! I have a 4.5ckm21-rv and when the barrery hi connected, the starter cranks without pressing the start button.
Old 03-06-2010, 11:49:55 PM
mark3885 mark3885 is offline
It would be greatly appreciated if you could send me the service manual and the operator install manual for the 4.5CKM21-RV. Please send it to mark3885@verizon.net
Thank you very much Mark
Old 04-20-2010, 12:41:21 PM
tlgardner tlgardner is offline
Hi,
I'm looking for any information you have on a 4.5ckm generator with a KT17 kohler engine. Any help you could provide would be very much appreciated. My email is t.l.gardner@hotmail.com
Thanks for your help,
Travis
Old 04-29-2010, 08:33:31 PM
ctmaz ctmaz is offline
Hi can you please email me a copy of this manual?
Thanks,
Chris
chrismaher1@cox.net
Old 06-14-2010, 08:55:22 AM
grizzlytfs grizzlytfs is offline
Smile Re: Kohler PDFs Available
I have a KOHLER CONFIDANT 5, 5CKM21 Spec# 101243 and need all manuals, service user and the like. Thanks and you can send to me at kb7voo@comcast.net Thanks again.
Old 06-16-2010, 10:53:11 AM
NikkiW NikkiW is offline
I was wondering if any of those would be for a electric plant
model 6.5R61
ser no 267406
spec no 505002347
kw 6.5
kva 6.5
rpm 1800
hp 12.5
volts 240/120
pf 1
battery volts 12
phase 1
cycles 60
Old 06-25-2010, 01:10:39 PM
jwt27ta6 jwt27ta6 is offline
Hello, I could use the repair manual for a propane kohler 4ckmr62 manual, SN #288041 Spec#101313, 4k watt. It is on a 1993 RV.
Mine doesn't even begin to start, all you hear when you push the start button is a buzz in the control panel...it isn't the starter solenoid. 1 guy told me that my be the fuel solenoid making the buzzing. Regardless, neither the starter or starter solenoid is doing anything.
The battery is good. My next step is to chk voltage to generator & starter solenoid. I suspect it is a relay bad in control box, but need manual or a good tech to direct me.
xnks
Jeff
Old 06-29-2010, 12:53:03 AM
GNation GNation is offline
i have a 4ckm21 model. u have any manuals on that model?
Old 06-29-2010, 08:41:58 AM
xnks
Jeff
Update: The starter solenoid was engaging, but even when I jumped across it manually, I got nothing. And when I measure the Voltage on solenoid when trying to start, it would get pulled down to 0V. After moving starter manually & moving the gear in & out into flywheel & some Liquid Wrench, I eventually got starter to start spinning & engaging. I broke the solenoid stud in process, but can manually jump it now & getting working.
It looks like just a standard solenoid, so hope I can match one up @ Auto store.
Old 08-14-2010, 11:27:18 PM
bhw2ijp bhw2ijp is offline
yes I need a service manual for kohler 4.5ckm21-rv
bhw2ijp@verizon.net
Old 09-03-2010, 01:11:41 PM
fuzzyswede fuzzyswede is offline
I just purchased a Kohler Generator at a local auction, Model 350 C 21K7, Spec 300 2A with a Tillotson MD30A carburator. It was in poor shape but complete, after extensive cleaning, etc., I got it running but need information for the correct governer / carburator linkage adjustment and carburator settings.
I would really appreciate a copy of your manuals for the following:
Let me know your charges when sending to mthyberg@westriv.com
Thank you very much,
Mike
Old 09-22-2010, 01:33:02 AM
petecosentino petecosentino is offline
Thanks for posting this I need the Kohler 4.5ckm21-rv service manual TP5206
Thanks a million
Pete
let me know if there is any charge
e-mail peter.g.cosentino@dom.com
Old 09-22-2010, 05:33:06 PM
RETCPO RETCPO is offline
Rob,
I could use PDF files for the following
Each a separate e-mail please.
Kleach5926@aol.com
Keith
Old 09-27-2010, 11:35:43 PM
avrej avrej is offline
Keith,
My name is Jim and I have a Kohler 4.5 generator set that needs work. I could really use some help like your pdf service manual; Kohler 4.5 ckm21-rv service manual TP5206.
my email address is
avrej@yahoo.com.
Thank you for your time and consideration,
Jim Avre
KOHLER of KOHLER Electric Plant rvaccaro2 Kohler Generators 2 05-03-2013 12:52:46 PM
Kohler K12-2 Steam Pig Kohler Generators 3 08-12-2012 09:23:33 AM
Wisconsin & Continental Engine Manuals--Free PDFs Jud Generators & Motors General Discussion 1 03-15-2007 11:11:36 AM
Kohler gen-set Al Wait Kohler Generators 1 10-06-2005 08:02:30 PM
Kohler 2 cyl.gen,set. Arthur Kohler Generators 1 07-21-2005 10:27:53 PM
