Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
Farm + Industrial Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers, pumps and antiquities of the industrial revolution.
Sharpening Buzz Saw Blades
this thread has 44 replies and has been viewed 18578 times
Old 01-31-2010, 09:27:48 PM
Rick Gilder Rick Gilder is offline
Default Sharpening Buzz Saw Blades
I use an old buzz saw belted to my Farmall tractor that I use to saw up firewood. It came from my great-uncle's farm and I used it with him when I worked there around 1980. At that time my dad borrowed it, removed the blade, and had it sharpened. I think it needs sharpening again. Is it possible to touch it up with a stone or file, or should I just remove it and have it professionally done? I only use it once per year.
Old 01-31-2010, 10:39:52 PM
butch vollmar butch vollmar is offline
Default Re: Sharpening buzz saw blades
If it's not in bad shape you can touch it up with a file following the profile of the last professional sharpener. However if is bad better have it redone by a pro. By the way new blades are still available. Make sure you have enough set in the teeth to aleaviate pinching the blade. My new blade has about 1/4 inch of set and works great. have fun. Butch
The Following User Says Thank You to butch vollmar For This Post:
Old 02-01-2010, 09:06:31 AM
KenK KenK is offline
Available where? Sizes? How much $$$ ? Who
Old 02-03-2010, 11:51:46 PM
Ken! I have sent you a private message regarding saw blades I hope you get it. If you don't, send me a message back. Butch.
Old 02-04-2010, 02:51:07 PM
Meco3hp Meco3hp is offline
Images: 62
Butch,
I'd also be interested in that info! Why not publish it for all to see?
Thanks!
Richard
Old 02-04-2010, 03:50:53 PM
Steve Kreiner's Avatar
Steve Kreiner Steve Kreiner is offline
Images: 14
I second that.
Old 02-04-2010, 08:37:30 PM
The only company still making circular saw mill blades I've been able to find so far is Simonds.
http://www.simonds.cc/pindex.html
There USED to be a number of saw dealers in Wisconsin but no more. Two that immediately come to mind are Harry R. Schell Sawmill Supplies at Blue River, WI, and Menominee Saw & Supply Co. of Menominee, MI, just across the Wisconsin border at Marinette.
http://local.yahoo.com/info-16765317...les-blue-river
http://www.menomineesaw.com/
Old 02-04-2010, 09:46:01 PM
gene w gene w is offline
Talking Re: Sharpening buzz saw blades
there is a place in rice mn. [blacksmith shop] that rebuilds and is able to make new saw blades fasinating place to spend an hour or two. One of the area blacksmith groups meets there from time to time [just checked google, rice mn blacksmith shop, and it will come up] [address & phone no.]
The Following User Says Thank You to gene w For This Post:
Old 02-04-2010, 11:03:26 PM
Because so many of you folks are from such a large area I would try simmons and ask for a dealer in your area. I am not trying to be difficult on this matter as I don't know how far I can go by letting this info out without getting in to trouble with the staker site. I am lucky, here in Michigan that I have a few saw dealers with a hundred miles of me that hammers, sells new blades and does the fitting up of saws both large and small. I hope this helps you out. Butch
Old 02-04-2010, 11:11:36 PM
HBurk HBurk is offline
I think that you're going to find a 28", or 30" blade rather expensive.
Old 02-11-2010, 02:12:45 PM
Did you find saw blades?
Old 02-11-2010, 08:08:52 PM
Sonny Reese Sonny Reese is offline
If you only use it a time or two per year, you need to file it just like saw chain---several times a day if cutting tough/hard wood!--I file mine all the time and have a Bellsaw sharp-all with circular saw holder (it handles 30" blades with no problem) It also has the setting anvil to put accurate and even set back into the teeth! thanks; sonny
The Following User Says Thank You to Sonny Reese For This Post:
Old 05-15-2010, 08:28:39 PM
Heins Heins is offline
I built a buzzsaw blade sharpener. It uses a shop grinder and wore out chop saw blades, it works great. If interested, let me know. heins
Old 07-16-2010, 07:59:54 AM
Dan O Dan O is offline
Heins, I'd like to see that saw Sharpener you made, can you post some pics or send it to me in a message please. I just restored a 32 inch Buzzsaw (see You Tube Video Post) and plan on using it an awful lot, year 'round. DanO'
Old 07-16-2010, 11:21:50 PM
I don't build buzz saw blade sharpeners to sell but I will show you how I build them. Once I have a blade in shape, I can sharpen them in about ten minutes. I sharpened a blade for a guy and he told me it cut better than when it was new. Anyone that uses a buzz saw needs to build a sharpener. I will try to post a picture of my sharpener if I can figure out how. I mount the blade flat on a wheel spindel so it will turn and I mount a shop grinder with a small chopsaw blade on a henge so it will go back and forth at the angle I want and all I have to do is hold each tooth to the chop saw blade. I can change the angle and sharpen the front or back of the tooth. If I can help, let me know.
Old 07-17-2010, 04:43:14 AM
badboy1950 badboy1950 is offline
hello Heins;
i would also like to see pictures of your sharpener.
a friend of mine has a buzz saw and his blade is dull and i would like to sharpen it for him.
Dan
Old 07-18-2010, 06:43:58 PM
If you send me your e mail address, I will e mail you pictures of my buzz saw sharpener.
Old 07-18-2010, 07:00:33 PM
HEINS, I Got the email & the Pics. Thank You Very Much, I will be making one simular ASAP. DanO'
Old 07-18-2010, 07:06:03 PM
Dan O: I am trying to post the pictures on this site and can't figure out how, "HELP".
heins
Old 07-18-2010, 07:13:39 PM
I'll attempt to do it
Drag saw sharpening Lou Quirch Drag Saw Collectors 10 05-09-2016 12:03:01 AM
Cub Cadet riding mower - the blades won't run! Please help Garden Tractors / Mowers / Scooters 6 05-06-2010 07:35:36 AM
Bucksaw sharpening David Scott Chain Saw Collectors 8 04-10-2010 07:39:43 PM
Reel Mower Blades trashman6062 Garden Tractors / Mowers / Scooters 3 09-02-2009 08:08:27 AM
Drag saw blades, would like few pics posted Mac Leod Antique Engine Archives 18 04-04-2004 07:27:49 PM
