Welding Shop
Lincoln SA 200 welder: please help
this thread has 8 replies and has been viewed 6787 times
Old 02-07-2010, 11:50:43 PM
maddenfarms maddenfarms is offline
Default Lincoln SA 200 welder: please help
I'm trying to rebuild a 1965 red face, we got it running and the 120dcv outlet and the exciter is working. The welder lugs only have 2.5 volts. We took the wires off the main brushes and the selector switch, we found no open circuits. Where do I go from here or where can I get information on how to find the trouble. Thank You.
Old 02-08-2010, 05:49:50 PM
Dempster Dempster is offline
Default Re: Lincoln SA 200 welder: please help
Make sure brushes are moving freely and armature is clean. Recheck all wires inside and connections. Make sure the main selector switch lugs behind panel are in position correctly not in between lugs. If it hasn't been running in a long time may have to flash it to excite the armature. Lincoln manual IM-471 for the Classic I welder has good flashing instructions and other trouble shooting instructions.
http://content.lincolnelectric.com/p...m/obsomenu.pdf
Contact them at Bill's or another local welder repair in your area too.
http://www.billswelderrepair.com/Engine-Drives.html
AWS forum also has a section dedicated to the SA200 under Gear and SA200.
http://www.aws.org/cgi-bin/mwf/forum_show.pl
The Following User Says Thank You to Dempster For This Post:
Old 02-11-2010, 06:32:13 PM
mooseye mooseye is offline
had a simular problem last time I started my sa. I had to polish the comutator and away we welded.
The Following User Says Thank You to mooseye For This Post:
Old 02-11-2010, 06:34:19 PM
Forgot to mention, Rats love to get in these old machines and build nests and eat wires.
Old 02-15-2010, 10:07:29 AM
Thanks for the reply. I thank my problem is in the main fields, I only have 20 ohms and should have 40. I guess I'll have to take the generator off and take it to Stumpf's. Any other ideas would be appreciated. Thanks, Monty.
Old 02-15-2010, 04:32:44 PM
Monty,
Many of us use coils from Hybriweld those fit better than the ones you can get from Lincoln now. Might also try Martinez in Louisianna hear good things about their coils but I haven't tried them yet.
http://www.hybriweld.com/
Martinez Electric Motor Service
Thibodaux, LA
985-446-6734
Old 04-25-2010, 09:44:26 AM
Update: Had a short in the armature. Used armature from rebuilders=$900, buy a old welder for parts, $500. Problem solved, Thanks everybody.
Old 04-28-2010, 04:02:05 PM
bobgil bobgil is offline
I was hoping to find a used machine around here for a price like that but i guess the gass fields have about taken all of them and run the prices up on the ones that are left.
I have not found a SA200 for less than $1500 even not running ones anywhere near me.
Bob
Old 04-28-2010, 11:46:54 PM
Back east and up north some running machines were going for $300 to $800 but when things pick up more now. Most any SA200 that runs here goes for $1200 on up. SA200 red face machines from 1960s will still bring $3000 on up the all copper pure DC machines weld better and still bring more.
Lincoln MIG Welder Chad Welding Shop 6 01-27-2010 02:29:24 PM
Lincoln 101 welder giacamo Welding Shop 2 10-22-2008 11:00:05 PM
OT-old lincoln welder Farmall Welding Shop 3 05-24-2008 10:14:54 AM
Old Lincoln welder - need help Ibrahim Abbas Welding Shop 3 03-25-2008 09:28:19 AM
Lincoln Welder Todd Branch Welding Shop 2 11-14-2000 08:46:06 PM
