LR-3927 Ser# C810557634/mod# 3.??OAJ-1R//160175 Weak Spark
this thread has 5 replies and has been viewed 1839 times
Old 03-22-2010, 10:54:27 AM
southland3 southland3 is offline
Default LR-3927 Ser# C810557634/mod# 3.??OAJ-1R//160175 Weak Spark
Need help. I recently purchased a used onan generator and now it will not fire up. It has a very weak fire @ the spark plug. I replaced the coil and still have the same problem. Any ideas?
Old 03-22-2010, 12:32:29 PM
Billy J Shafer's Avatar
Default Re: LR-3927 Ser# C810557634/mod# 3.??OAJ-1R//160175 Weak Spark
Could be bad points or condenser.
Old 03-22-2010, 01:51:31 PM
Exclamation Re: LR-3927 Ser# C810557634/mod# 3.??OAJ-1R//160175 Weak Spark
If the ignition wires are old, they may be leaking voltage as well.
Old 03-22-2010, 02:25:32 PM
Major Tom Major Tom is offline
Check and (if necessary) set the breaker points gap to 0.020". Also a quick burst of electronics cleaner across the points may be indicated because an oily mist sometimes works its way up from the crankcase.
Best wishes,
The Following User Says Thank You to Major Tom For This Post:
Old 03-29-2010, 11:17:39 PM
Default Ser# C810557634/mod# 3.??OAJ-1R//160175 Weak Spark
Had new points & condenser installed. Fired up and ran good for two days, now no fire at points. Any suggestions??
Old 03-30-2010, 04:01:30 PM
Not sure if your genset has an oil pressure switch but if so this is a likely candidate for intermittant failure. If one is present jump across it temporarily and see if it runs. Also check and trouble shoot any high limit temp. switches on the heads that might be in line with the ignition circuit.
Best wishes,
Weak Spark mrmechanic1965bc Military MEP and Aircraft Gen-Sets 1 06-08-2009 07:26:54 AM
Weak spark for sure Elwood Antique Gas Engine Discussion 1 05-17-2009 11:18:07 PM
Ihc M 3hp weak spark jmsolomonson Antique Gas Engine Discussion 7 04-10-2008 10:05:19 AM
LB Mag weak spark Bill Schaller Antique Engine Archives 7 08-12-2004 07:33:41 PM
Weak spark - Help Nathan Antique Engine Archives 2 03-09-2000 02:32:34 PM
