Needle Valve Settings for Walbro LMG Carb
this thread has 17 replies and has been viewed 4797 times
Old 04-07-2010, 02:16:57 PM
Oberon67 Oberon67 is offline
Default Needle Valve Settings for Walbro LMG Carb
I have a rebuild kit on order for the carb on my Clinton-powered tiller. The carb is a Walbro LMG with choke.
When I get the rebuild done, there are two needle valves in particular I'm concerned about. One is in the middle of the float bowl and points upward. The other is on the left side of the carb, next to the engine intake.
How should I set these screws so the engine can start and run?
Thanks in advance...
Old 04-07-2010, 11:20:48 PM
manioso manioso is offline
Default Re: Needle Valve Settings for Walbro LMG Carb
The needle on the bottom of the float bowl is the main jet, and initial setting is to tighten gently, then turn out 1 1/2 turn. The jet on the side of the carb is the idle mixture, and it is set at 1 1/4 turns. In both cases be sure you tighten gently. If you force too hard, you will damage the needle tip, making carb difficult if not impossible to adjust properly.
When you disassemble carb be sure to replace main nozzle with the replacement nozzle provided in the kit. Do not reuse the original main nozzle. The original is cross drilled at the factory after assembly to provide fuel passages. When you unscrew and then replace you'll never get it clocked exactly right and fuel flow will be compromised.
The replacement nozzle has an annular undercut, permitting fuel flow no matter where the nozzle finally tightens up.
The Following User Says Thank You to manioso For This Post:
Old 04-08-2010, 09:32:32 AM
After reviewing the parts kit I got in the mail last night, I realized that it came with the main jet needle and the nut that secures the bottom of the float bowl (which also is the mounting point for the main jet needle), but it did not include the main jet (the needle valve seat).
So it's back to parts scrounging for me. I did find this on e-Bay... it's part number 182 37... but I don't know if it's the right jet for a Walbro LMG.
I get the impression that, given the amount of dead gas and varnish and dust and tank rust that has been through this machine during its life, a new jet is mandatory. How can I find out which is the correct part?
Old 04-30-2010, 02:17:51 PM
tasturbo86 tasturbo86 is offline
I am aware of the jet replacement recommendation above, but I have never found the correct kit for rebuilding these carbs. I usually just replace the gaskets and that gets me going.
Old 05-13-2012, 09:50:26 PM
martinf martinf is offline
Wow. SO this is what's going on with my clinton LMG 4 carb problem!! I've been messing with this thing all day and could not get enough fule flow unless I was half-choking the dang thing. i cleaned the carb and soaked and cleaned and routed out every passage way...and still not enough fuel.
SO, my question is: what is the deal with the cross0drilled passageways? Do they need to line up to holes in the main jet hole in the carb body. I can't quite picture what's going on here. And, the most important question...how do you line the holes back up? I'm not up for getting a rebuild kit with the improved main jet. Certainly there's a way to line it up!
Sure would appreciate any help here.
Old 05-14-2012, 12:53:31 PM
Road Torpedo Road Torpedo is offline
They took care of the main jet problem by under-cutting a shallow circular groove in that area were that hole is in the jet. The part that so called "wouldnt" line back up.
This can be acomplished EASILY by someone with a lathe and a squared cut off tool. You would just ease the tool into the peice ti'll a shallow groove was aparent in that area.
That was enough to do the job.
The replacement jets were nothing more BUT that, with a groove.
The Following User Says Thank You to Road Torpedo For This Post:
Old 05-14-2012, 01:59:47 PM
OTTO-Sawyer's Avatar
If you don't have access to a lathe, you can carefully file a groove in it that would do the same thing.
Old 05-25-2015, 01:29:32 PM
Holy thread necrophilia, Batman! It's me again!
New old carb this time... and this one has "Clinton" stamped on it, and instead of the simple screw-type needle valve in the main jet, this one's got a 3/16ths nut threaded into the float bowl retaining nut, and the needle valve is seated into that. Same deal? Seat gently, then back off 2.5 turns?
It's a little hard to make out, but you can see it in the bottom of the pic if you squint just right.
Old 05-26-2015, 11:50:52 AM
As you can see, this carb has a hand-adjustable lever/indicator for the main jet. This flummoxes me, as I don't know how to get the carb in the ballpark for operation.
Old 05-26-2015, 11:16:32 PM
@manioso, do you know how to manage one of these?
Old 05-27-2015, 05:50:39 AM
Thiel's Avatar
Thiel Thiel is offline
Has anyone used the repro carbs which are offered between $ 15-20 ?
Most reviews are positive, I may try one on my Clinton, before fiddling for a day with old one.
Old 05-27-2015, 12:21:35 PM
I was unaware of these. Got a link?
Old 05-27-2015, 02:11:44 PM
Thiel's Avatar
I don't have a link in front of me but do a search on eBay.
don't be too focused on Clinton also search for Tecumseh H25 or H30 carburetor I believe it is similar. obviously there are differences in various LMG settings, but sometimes we have to work with what we get.
Old 05-27-2015, 02:23:47 PM
Bolens 1000 Bolens 1000 is offline
That red Clinton carb should take this kit
https://bolenspartsandsupplies.com/s...5-30359-31390/
I would be very leary of a carb costing $ 15 !! I get a few requests for guys who bought an aftermarket briggs carb on ebay but since they are made in china no service parts are available nor do any OEM parts fit them. I always like to stick with OEM if possible.
Old 05-27-2015, 08:50:42 PM
Guys, I'm grateful for the suggestions, but the carb I've got is perfectly fine. I have put a carb kit in it, and all the relevant parts are new and in good working order.
My question is, how far do I need to back out the idle and main jet needle valves in order to get me in the ballpark to make the engine run? I can adjust after that, if I can just get the thing started.
---------- Post added at 08:50 PM ---------- Previous post was at 07:51 PM ----------
I did a search... the Tecumseh H25 and H30 carbs are Walbro LMBs. They won't work... the block stud spacing is different, wider, and they won't bolt up.
Sadly.
Old 05-28-2015, 08:27:26 AM
Generally about 1-1/2 turns will get you set at the standard setting
Old 05-28-2015, 05:23:06 PM
True for the relatively newer, long-stem needle valves. I was able to establish that my carb uses the older short-stem needle valve, which takes a default setting of about 1/4 turn out. I found that I was able to start my engine on that, and that the sweet spot was at about 3/8ths of a turn out.
I then proceeded to till the snot out of the rest of my garden. It's late, yes, but we have a long growing season here.
Old 05-28-2015, 08:06:57 PM
I was able to find that information here.
Need Help on a BFA Walbro Carb LeeZ Onan Generators 8 12-30-2009 09:23:37 PM
Clinton Mdl# 500 Walbro Carb Question wayne p keller Small Air Cooled Gasoline Engines 7 08-02-2009 11:02:54 PM
Witte 4 hp carb settings Ken Griffard Antique Gas Engine Discussion 1 10-30-2008 11:43:18 PM
Valve Settings Charlie Gale Steam Stationary Engines, Traction Engines, Steam Boats 0 08-03-2007 12:46:33 PM
rod bearing needle valve for carb. jerome lillie Antique Engine Archives 0 07-22-2001 05:28:28 PM
