Generac Generators (SEARS, etc.) Restoring, maintaining and operating Generac generators.
Removing Generator from engine
this thread has 3 replies and has been viewed 5479 times
Old 04-24-2010, 04:29:21 PM
fanatic fanatic is offline
Default Removing Generator from engine
Have a older 3000 Watt generator on a Tecumseh 6hp engine Need to remove generator from Engine not having any luck. looks like generator end plate next to motor has bolts into engine case & probably have to remove outer shell of Generator to get to them. I have removed the bolt out of the end of the crankshaft, unable to remove generator shell.
Old 04-24-2010, 04:36:39 PM
Warren914 Warren914 is offline
Default Re: Removing Generator from engine
Hold the engine and generator vertically by the rotor. Back the bolt off slightly and hit it with a hammer. It will break free from the tapered shaft and come off easily.
Old 04-26-2010, 03:01:47 PM
Thanks for the info I will try that.Do you know if the whole unit will come off or everything but the Generator endplate at the motor?
Old 04-28-2010, 04:28:56 PM
It's just to remove the rotor from the tapered engine shaft. Everything else will be bolted on somewhere else.
Removing generator head from engine Onan 55.0en infastruct Onan Generators 14 04-13-2010 07:50:52 AM
Removing flywheel on small engine Jim Cobb Small Air Cooled Gasoline Engines 11 02-10-2009 12:32:47 AM
Removing generator from a Kohler 1A22 RElfers Kohler Generators 1 09-07-2008 06:33:34 PM
Removing generator back end rmarshall Generators & Motors General Discussion 5 12-28-2006 04:07:15 PM
Removing flywheels from engine Tim Antique Engine Archives 5 06-07-2001 12:22:38 AM
