Go Back   SmokStak > SmokStak® Support and Information > Smokstak Forums Meet and Greet
Smokstak Forums Meet and Greet Welcoming Smokstakers New and Old, a place to say a bit about yourself and post a photo if you're really brave. If you have a technical question, please post it on one of our other boards.
Gravely L-8 Help in changing oil!
this thread has 4 replies and has been viewed 5136 times
Old 04-29-2010, 06:18:30 AM
artie artie is offline
Default Gravely L-8 Help in changing oil!
I just purchased an old L-8 Gravely tractor with from tiller attachment. Can someone tell me where to change the oil? I've searched but can't locate and don't have a user's manual. Thanks.
Old 04-29-2010, 08:34:37 AM
Elden DuRand's Avatar
Images: 6
Default Re: Gravely L-8 Help in changing oil!!!
Artie:
The oil drain plug is located at the bottom of the differential. In the "T" head Gravely tractors, the engine, tranny and bands were bathed in the same oil.
There's also a strainer on the oil inlet line inside the diff housing.
After changing the oil, it's good to make sure that the oil pump hasn't lost prime. If your Gravely doesn't hava an oil pressure gauge (most don't), you can check to see if it has pressure by taking off the oil fill cap and looking for a stream of oil coming out of the brass piece a couple of inches below the top of the filler neck.
Caution, you could get a face-full of oil spray if you open the cap while the engine is running at speed.
Take care - Elden
Take care - Elden
http://www.eldensengines.com
Old 04-29-2010, 09:02:27 AM
joneg joneg is offline
if i remember correctly the drain plug is actually one of the bottom bolts in the axle housing flange. don't remember which side or if both
Old 04-29-2010, 01:20:42 PM
Preston Wells's Avatar
Preston Wells Preston Wells is offline
Images: 37
I think its the bottom bolt of the right axle housing.
"There is more to life than what we see"
www.youtube.com/user/theoldengine1
Preston
FL
Old 05-01-2010, 11:49:55 AM
Bill Decker's Avatar
Bill Decker Bill Decker is offline
If you're lucky, the tag may still be on the bolt. It is the very bottom bolt though.
If you don't teach humor to children when they are small, they will grow up to be adults with no humor at all
New toy: Gravely mower Regs Garden Tractors / Mowers / Scooters 7 06-04-2010 08:54:50 AM
Gravely D starting Tim B Garden Tractors / Mowers / Scooters 5 04-05-2010 08:22:55 PM
Older Gravely L I drmag64 Unidentified Engines 2 04-30-2009 06:16:32 PM
gravely skip landis Antique Engine Archives 3 06-02-2004 08:20:56 AM
Gravely walk behind Marty Antique Engine Archives 5 09-23-2002 03:59:46 PM
