Ford buzz coils
Thanks to the many threads on here i have tackeled repairing my Ford coils. The one thing I am...
this thread has 5 replies and has been viewed 1518 times
Old 05-11-2010, 07:28 PM
Tim Litzenberger's Avatar
Tim Litzenberger Tim Litzenberger is offline
Default Ford buzz coils
Thanks to the many threads on here i have tackeled repairing my Ford coils. The one thing I am not sure of is checking the AMP draw. I found on this site to set amps at .85 to .95 amps. Is this using 6 or 12 volts? I know on AC current, as the voltage increases the current is less. Dose the same apply for DC volts. Thanks !! Tim
Old 05-14-2010, 12:02 PM
Elden DuRand's Avatar
Images: 6
Default Re: Ford buzz coils
Tim:
With a buzz coil, the current is always higher as the battery voltage increases - BUT - it doesn't increase in direct proportion due to the interruptor.
You need a DC Ammeter to measure the primary current.
Take care - Elden
Take care - Elden
http://www.eldensengines.com
Old 05-14-2010, 02:02 PM
Ken Majeski's Avatar
Images: 38
I Generally set mine on 12 Volts... I find that 6 or 12 don't really make that Much difference in current draw... Like Eldon said I believe it's due to the action of the interupter points.
Actually in the car when running on Magneto they ran on up to 35 or so volts of AC at High speed not 6 volts DC like many people think...
Ken Majeski, Ellsworth Wis.
Old 05-14-2010, 07:13 PM
THANKS for the input guys!! Tim
Old 04-26-2012, 04:09 PM
colo colo is offline
Default Ford buzz coils NUTS for contacts
Good evening,
I'm looking for contacts of my Buzz Coil (Ford type) the nuts.
What type of thread have? They are 10-32 UNF?
I am Italian, so I'm types of threads a little strange for me.
Davide
Old 04-26-2012, 07:11 PM
PaulGray's Avatar
PaulGray PaulGray is offline
Images: 37
Colo-
The nuts are 12-32 NEF (national extra fine). The only way I could reasonably get them was to take 10-32 brass nuts and re-tap them to 12-32. You can pick up the tap from the big supply houses. The tap I used was made in Poland if I am not mistaken. First time I tried to repair these coils I bought 2 boxes of 12-28 nuts and found out they were not a good fit!
The Following 2 Users Say Thank You to PaulGray:
New Buzz coils... Jim Sherman Antique Gas Engine Discussion 14 05-05-2010 10:04 AM
Buzz coils Kevin Behnke Antique Engine Archives 1 05-10-2004 07:35 PM
Buzz Coils dave in PA Antique Engine Archives 6 07-03-2002 12:17 AM
Re: buzz coils Carl Mehr Antique Engine Archives 0 12-19-2000 12:08 AM
buzz coils Kevin Antique Engine Archives 3 12-16-2000 11:11 PM
