When was my ONAN built?
this thread has 13 replies and has been viewed 1428 times
Old 05-13-2010, 08:16:01 AM
TwowheelerVA TwowheelerVA is offline
Default When was my ONAN built?
I know this is a typcally asked question, but could not find the references in the threads....serial number: c780306530
Old 05-13-2010, 08:46:39 AM
bobbyz72 bobbyz72 is offline
Default Re: When was my ONAN built?
c = march 73 = 1973
The Following User Says Thank You to bobbyz72 For This Post:
Old 05-13-2010, 08:59:14 AM
mrmegoo mrmegoo is offline
March, 1978
Old 05-13-2010, 10:03:13 PM
Gunny Gunny is offline
March 1978
Old 05-13-2010, 10:12:16 PM
opps sun was on laptop screen that day.....
Old 05-14-2010, 08:55:23 AM
Billy J Shafer's Avatar
Sure it was
Old 05-14-2010, 09:41:05 AM
Ted_Cool Ted_Cool is offline
Wink Goggles
Beer goggles interfere with reading...
Irish whiskey is better for scholarly pursuits.
The Following 2 Users Say Thank You to Ted_Cool For This Post:
Old 05-24-2010, 07:33:20 AM
Default Onan 5kW Re: When was my ONAN built?
Got into the 5KW over the weekend. In the process of putting in new battery cables and replacing the 110V outlets with new ones. Engine looks solid and nice compression. Need to find the right color to repaint this, it needs it!
Old 05-24-2010, 01:21:54 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: When was my ONAN built?
If you unit has local Outlets, it will be a Contractors version of the CCK, which has a different Wiring Diagram and Safety Shutdown Systems, from the Stationary or Motorhome versions. Maybe one of the Resident SmartGuys, that has access to the Onan Build List will take your serial Number and come back with your exact Model and Spec Code.
Bruce in alaska
Old 05-24-2010, 02:55:23 PM
It is a contractor version
Old 05-24-2010, 03:21:30 PM
That is one of Onans portables that you need a crane to move.
Old 05-25-2010, 12:18:54 PM
Dave Edmonds's Avatar
Dave Edmonds Dave Edmonds is offline
If it's manual start, I hope you have a strong back! The CCK I have was originally a contractor version and I had virtually given up on it, but I found a MCCK locally with a bad engine that I bought for $100. Disassambled both, scrapped the MCCK engine, married the MCCK genend to the CCK engine (everything fit perfectly), and - - Viola! - an electric start Onan! When it was manual-start, I had to flash the field occasionally to make it gen - you may have to as well.
Dave Edmonds
Old 05-25-2010, 09:17:20 PM
It's electric start, with large wheel barrow type wheels and a 1" axle so its pretty easy to move. I ordered paint so painting is next. It now has new battery cables, new outlets, engines turns over nicely. Only issue is the vertical risers on the cage are battered, but that's minor.
Old 05-28-2010, 07:55:35 AM
It has not run a a couple years according to the guy I bought it from, it had a frayed ground cable/bad contact on the chassis connection of the negative side of the battery. New cables, a float bowl flush, and it started up and ran very smoothly, held voltage nicely under load. This weekend is the paint job and also bought new trailer wheels. I'll post some before and after pictures when I am done. Cannot find decals for the white labeling, so will be making mine own.
Fairbanks Morse built for Onan WilliamM Onan Generators 10 04-23-2016 09:41:58 AM
What year was this ONAN built? OnanTheBarbarian Onan Generators 6 02-22-2010 03:27:40 PM
When was my Associated built? r kline Antique Gas Engine Discussion 1 04-22-2008 01:18:41 PM
Who built it. Etc, Etc. Daniel Dorece Garden Tractors / Mowers / Scooters 2 09-12-2007 04:35:07 PM
Was there any built ? Marty Antique Engine Archives 23 05-01-2003 12:20:03 PM
