Go Back   SmokStak > SmokStak® General Discussion > YouTube Old Iron Videos
YouTube Old Iron Videos A place to show your ON topic movies of antique engines and old iron.
3hp Ohio pushrod
Video of the engine I brought home from the Heidl sale on 6/26/10. Dick had it bored and sleeved...
this thread has 4 replies and has been viewed 876 times
Old 06-28-2010, 10:47 PM
Mike Monnier's Avatar
Hoarder
Default 3hp Ohio pushrod
Video of the engine I brought home from the Heidl sale on 6/26/10. Dick had it bored and sleeved when he bought it 20 years ago, so now it just needs to run and be fine tuned. Hopefully it will be dialed in and running smooth at the Greenville, OH show 7/8-7/11!!
The Following 9 Users Say Thank You to Mike Monnier:
Old 06-28-2010, 11:23 PM
nar's Avatar
nar nar is offline
Images: 51
Default Re: 3hp Ohio pushrod
It sounds good Mike & it went to a good home. Dick loved to keep files on everything. (before & after, dates & where he got engines from)
-Nick
http://rowland24.20megsfree.com
Old 06-29-2010, 12:08 PM
Hoarder
The before picture is neat. It looks better now than what he started with! The tag that was tied to the pushrod had the date he got it from Bill and the date for the bore and sleeve job.
Old 06-29-2010, 01:08 PM
xplor xplor is offline
How is the crankshaft lubricated?
Old 06-29-2010, 08:58 PM
Hoarder
The cast "wells" on top of the main bearings are filled cotton string and oil. The string is to control the flow of oil into the bearing. It can get a little messy as the oil tends to run down the crank throw and get flung off. It requires a little more attention than a grease cup, but is very effective at keeping the crank oiled. The string also acts as a crude filter to keep contaminants in the oil out of the bearing.
The Following User Says Thank You to Mike Monnier:
I need a JB pushrod for less than my right leg, used OK Bruce vernon Onan Generators 16 04-29-2010 10:54 PM
2 1/4hp united (A) help pushrod P Grogan Antique Gas Engine Discussion 3 10-26-2009 09:04 AM
The last intact steam tow-boat in Ohio headed to an Ohio Shipyard Farquharman Stationary Steam & Traction Engines 5 10-13-2009 09:21 PM
Ohio pushrod 6 h.p. original color. Jim Cook Antique Gas Engine Discussion 2 08-20-2009 03:16 PM
Jaeger 3.5 HP Pushrod Russell M Antique Gas Engine Discussion 3 03-30-2008 06:19 PM
