MEP-002A oil filter/fuel strainer/aircleaner question
First post. I recently purchased a MEP-002A 5KW, Generator at a Government auction. I got the...
this thread has 7 replies and has been viewed 3360 times
Old 06-29-2010, 06:17 PM
carlduhon1 carlduhon1 is offline
Default MEP-002A oil filter/fuel strainer/aircleaner question
First post. I recently purchased a MEP-002A 5KW, Generator at a Government auction. I got the manual for it and it shows the following:
Fuel Filter: Fram Corp. Model: 244350 Part No. C-1125PL
Fuel Strainer: Fram Corp. Model: Part No. 244344 Fuel Strainer Element: Part No. C1824
Air Cleaner: Donaldson Co. Inc. Model: Part No. KAX 00-3851 Air Cleaner Element: Part No. P101222
Engine Oil Filter: Fram Corp. Model: Part No. 170429 Oil Filter Element: Part No. MS35802-2
Before trying to start it I want to replace the filters, etc.
I am having a hard time figuring out what are comparable filters, etc. Can anyone give me the Manufacturer and part number for the above items. I would really appreciate it.
Old 06-29-2010, 08:55 PM
Jim Kinler Jim Kinler is offline
Default Re: MEP-002A oil filter/fuel strainer/aircleaner question
the strainer you can clean. the oil filter 1004 doesnt come with the correct gasket. the fuel filters 3113 do.
oil filter napa 1004
fuel filter napa 3113
air filter napa 2222
oil filter gasket napa 5108
The Following User Says Thank You to Jim Kinler:
Old 06-29-2010, 09:16 PM
Isaac-1 Isaac-1 is offline
One of the regulars over on the steel soldiers web site makes machined spin on oil filter adapter that uses easy to find filters if you want to go that route. I don't own a MEP-002, but I seem to recall reading that there is a commonly available NAPA oil filter that will work in it with minor modification (punching an oil return hole or something).
Ike
The Following User Says Thank You to Isaac-1:
Old 06-30-2010, 07:08 AM
m38inmaine m38inmaine is offline
Best to order them from rockauto.com and use the original fram numbers. If you buy cross over filters the gaskets won't be correct and the fit is not good. The strainer can be gotten from delks surplus, I paid $25 for a new one, but unless it's missing or damaged can be easily cleaned.
Old 06-30-2010, 07:16 AM
Should have provided the Fram numbers above.
Oil Fram CH6PL
Fuel Fram C1125PL
TM call out for oil/filter every 100hrs so I stock up.
The Following User Says Thank You to m38inmaine:
Old 05-21-2012, 08:45 AM
gandsllc gandsllc is offline
Can these Napa filters be used on the Libby MEP002A as well as the Onan?
Old 05-24-2012, 12:34 AM
coyote62ny coyote62ny is offline
napa filters are what they are junk. they are to short to fit the fuel filter cans properly and make a good seal. and the oil filter requires bending the fingers in the bottom of the can. if you do this then you cant use the proper fram filters just best to get fram ch6pl oil filter 4.90 at race mart fuel filter c1125pl 6.09 at race mart. you cant even buy napa crap filters for that.
Old 05-25-2012, 10:41 AM
amolaver amolaver is offline
uhh, actually, fram filters are notoriously poorly made (go search for fram cardboard destroyed engine), while napa filters are generally high quality wix or baldwin mfr'd. the crossover might not fit the MEPs, but that is not indicative of the filters construction quality.
you might also consider doing this much cheaper spin-on conversion - http://www.smokstak.com/forum/showth...+on+conversoin
i haven't done it yet, but am planning for it in the fall since almost EVERY OTHER filter is more well made than fram. even walmart's house brand supertech filters are more well made using metal end caps. if i get really ambitious, i may even pull the factory fuel filter setup and get a standard spin-on filter & head assembly to ditch the cartridges all together.
ahm
Onan MEP 016B Military Fuel Filter & Air Filter (Help) Doogdoog Onan Generators 10 04-09-2010 08:22 PM
MEP-002A fuel system problem faraday Military MEP and Aircraft Gen-Sets 16 11-08-2009 05:31 PM
Filtration: Fuel Strainer? Anyone have a Photo of F/M fuel-line FUEL STRAINER? DerekC Antique Gas Engine Discussion 1 11-17-2007 05:10 PM
MEP 002A Fuel/Oil Info... RIKK Onan Generators 3 07-22-2007 07:48 PM
Onan MEP 002A oil filter INFO? RAYMOND Onan Generators 1 10-22-2005 03:24 PM
