Onan generator shuts down after 5-10 minutes
this thread has 3 replies and has been viewed 6186 times
Old 07-02-2010, 05:02:38 AM
rgraffeo rgraffeo is offline
Default Onan generator shuts down after 5-10 minutes
I have a Onan 4.0 BGE/FA 261100P generator.
It runs abour 5-10 minutes then surges & shuts down either with or without a load.
I replaced the coil (had a weak spark), fuel filter & new carb(was running rough).
I've jumped out the fuel pump & even tried running it off a gas can but still stops.
Check the valve backlash & checked the cylinder compression, both were 130#.
When the motor shut down we checked the spark & it was a good blue spark.
At the coil we never lost voltage, stayed 11.85 volts.
Also jumped out the oil pressure switch without luck.
Does anyone have any suggestions to the cause?
Old 07-02-2010, 09:10:02 AM
bobbyz72 bobbyz72 is offline
Default Re: Onan generator shuts down after 5-10 minutes
IF you know you have spark when the engine dies, then what about air, make sure the choke is not closing. If thats not it... you have a fuel problems. Try a new fuel pump, i had the same problem few weeks ago, drove me crazy trying to figure out simple problem, because the fuel pump would pump when i disconncted the line.
The Following User Says Thank You to bobbyz72 For This Post:
Old 07-02-2010, 11:14:25 PM
Ben Cowan Ben Cowan is offline
You might also consider replacing fuel hoses. Our great gasoline with alcohol often causes many fuel lines to deteriorate rapidly when gas stays in lines. I recently reviewed a 2006 manual for a subaru robin engine, they recommend changing fuel lines yearly. Could you be pulling a vacum on fuel tank? Plugged vent can be hard to find. Luck, Ben
Old 07-02-2010, 11:35:08 PM
Guys thanks for the help.
I already changed the fuel hose going to the fuel pump. I took off the gas cap & blew low pressure air into the fuel tank to insure the metal line to the tank did not have pluggage.
I made up a pressure gauge so tomorrow I can test the fuel pump pres to make sure its not pumping too much. I was told the fuel pump should put out 3-5 psi.
Onan runs then shuts itself off Raven Onan Generators 45 02-12-2012 02:44:07 PM
Kohler 10roy generator shuts down immediately wap Kohler Generators 9 07-17-2010 09:14:38 PM
My Hercules 1.5 E shuts down after about 20 minutes. Dave H Antique Gas Engine Discussion 20 08-25-2009 10:31:19 AM
Onan 3.0kw Marine Generator shuts off after 15 minutes CRay265 Onan Generators 5 07-30-2009 01:05:02 AM
Onan generator/ starts then shuts down Styners4x4 Onan Generators 3 06-22-2009 06:04:42 PM
