Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Champion Boat Motor
this thread has 7 replies and has been viewed 4492 times
Old 07-13-2010, 05:52:04 PM
Jim Scott
Default Champion Boat Motor
Just picked up a champion 11/2 horse boat motor. Has good spark and good compression.was wondering if anyone knew what the mix on the fuel should be. It has a no. Of 1945 dont know if this a serial no. Or the year built. Thanks for any information. Jim scott
Old 07-14-2010, 07:48:25 AM
Arlie Levy Arlie Levy is offline
Default Re: Champion boat motor
16-1 non det oil 8 oz to 1 gallon
Old 07-14-2010, 01:16:46 PM
Exclamation Re: Champion boat motor
Does the engine have a horse shoe shaped tanl? I had a champion, it was a sweet running engine. As Arlie said, 16:1 (1 cup to 1 gal) SAE 30 Non Detergent oil. DON"T use the modern oils in it! It does not have roller bearings, just plain bronze, both on the mains and the con rod. It will smoke a bit until it warms up. Nice find!
Old 07-14-2010, 02:28:43 PM
Jim Scott
Default Re: Champion Boat Motor
thanks for the info guys appreciate it very much. yes it does have the horseshoe tank! thanks jimj
Old 09-09-2010, 07:47:46 PM
billl6172 billl6172 is offline
i used champion motors when i was a kid. i used one half pint per gal.
Old 09-10-2010, 12:25:25 AM
JoeCB JoeCB is offline
There is no problem with using the modern 2-cycle oils in the old plain bearing motors. Just be sure and use the original recommended mix ratios... 16 to 1 will be good for your motor.
The new oils will run much cleaner, less smoke and plug fouling. I use the new stuff in all my outboards from 1920's thru 1960's with no problem. The old ones run as rich as 8:1 with clean plugs.
Joe B
Old 07-15-2011, 11:32:01 AM
petervg petervg is offline
where can you find parts for champion boat motor. where do you find the year on the motor?
Old 07-15-2011, 11:53:49 AM
Doug Oldenburg's Avatar
Doug Oldenburg Doug Oldenburg is offline
I have quite a few parts for a couple of model's of champion motors. Also a couple complete motors, both styled & unstyled. On the parts,the main thing would be trying to find where I put them years ago. .....
"So Much Iron & So Little Money"
I have an old boat motor with no name anywhere on it soulreeverz Antique Gas Engine Discussion 4 06-16-2008 10:38:59 PM
Flambeau Boat Motor Frank Martin Antique Marine Engines and Outboard Motors 5 05-27-2006 07:51:46 AM
Boat motor BrainAllinger Antique Marine Engines and Outboard Motors 5 03-15-2006 09:02:52 PM
Mystery Boat Motor John Newman, Jr. Antique Marine Engines and Outboard Motors 5 08-07-2005 09:27:05 AM
OLD boat motor grassfarmer Antique Marine Engines and Outboard Motors 5 07-26-2005 09:22:33 PM
