OTCU 400 Transfer switch
hey guys, I got a good question for you, I got this customer that wants to wired in a relay that...
this thread has 3 replies and has been viewed 891 times
Old 07-22-2010, 06:15 PM
Cat Man Cat Man is offline
Default OTCU 400 Transfer switch
hey guys,
I got a good question for you, I got this customer that wants to wired in a relay that fires when the generator is running. So it can fire an alarm. The generator does have a remote panel with a generator run light on the panel. I was wondering what would be the best route to wire in the relay? I should say the proper way to wire in the relay, or is there a place already in the transfer switch that I can use?
Mark
Old 07-22-2010, 06:23 PM
Default Re: OTCU 400 Transfer switch
By "running" do you mean "making power", or do you mean the "engine is operating"?
Old 07-22-2010, 06:57 PM
Billy J Shafer's Avatar
If you want generator running it will come off of the genset. For generator supplying power it will come from the transfer switch.
Old 07-22-2010, 10:08 PM
Gunny Gunny is offline
Generator running means its making power. (We hope)
Relay that picks up (is powered by generator output) would be how I'd do it in the ATS.
In thinking about it, there are at least 4 ways to do this.
OTCU has a set of aux contacts that indicate position of the switch.
Transfer Switch don-mar Onan Generators 1 12-19-2009 05:09 PM
Transfer Switch Sean W Onan Generators 2 07-04-2009 12:44 PM
Transfer Switch FisherManJohn Generators & Motors General Discussion 28 07-04-2009 12:33 PM
DJC transfer switch? DieselCJ Onan Generators 8 07-04-2009 12:16 PM
Transfer switch help d6btex Generators & Motors General Discussion 9 10-14-2007 07:49 AM
