How to rewind a starter armature?
this thread has 9 replies and has been viewed 8702 times
Old 07-30-2010, 06:10:42 PM
yachtwork yachtwork is offline
Default How to rewind a starter armature?
We are using a 24v starter motor to drive an anchor winch. It lasted about 8 years then burned up. The armature is cooked and I need to rewind it. Anybody know of a link to instructions on rewinding a starter armature? Maybe some quick tips? I'm the ships engineer and pretty handy and have re-wound alternators in the past. The winch maker is out of business and were in French Polynesia where getting anything done is a real challange thus I'm happy to do it myself.
Looking for ideas.
Scott
---------- Post added at 05:10 PM ---------- Previous post was at 05:07 PM ----------
By the way this is a reversable starter motor. We reverse polarity and the winch changes direction.
Scott
Old 07-30-2010, 07:33:35 PM
K D Redd K D Redd is offline
Default Re: How to rewind a starter armature?
If you reverse polarity and the winch/motor reverses, the field for this motor must be permanent magnet. This make me think of the small 12 volt starters used on small engines. Most but not all of these starter use a permanent magnet field.
I have also reworked a 12 volt starter used on 60's and 70's Chrysler vehicals as winch motors. These are also a 12 volt motor BUT they have a wound field. What makes them easier to reverse than most starter motor is, the armature winding and all of the field coils are in series. It is easy to modify the internal connection of the field coil and use four relays to reverse the motor. Two relays are used in each rotational direction.
I never have rewound anything. I let a shop who specialise in this work do it, but where you are at YOU do not have much choice.
Kent
Old 07-30-2010, 08:24:15 PM
The main thing to do is carefully disassemble it so you know how to wind it again! Once you take all the windings off, if you aren't sure then, you're sunk!
Then you need a source of "magnet wire", "fish paper" and "varnish".
Old 07-30-2010, 11:14:47 PM
Trevor A Cole Trevor A Cole is offline
You have picked one of the most difficult things to rewind. It's not the technology but rather the physical difficulty of winding it even if you have a source of wire given the wire is probably rectangular section. If the windings were welded to the commutator bars originally you will have great difficulty reproducing the robustness of that. How about telling us with words and pictures what you have got to start with and we may be better able to give good sound advice. Why did it last 8 years then burn out? Is it a factory built item or home grown? From a safety point of view a new anchor winch seems like a good investment to me.
Old 07-31-2010, 03:04:41 AM
John Newman, Jr.'s Avatar
Is it possible to find an old junked forklift truck with a usable motor in it. Would surely take a bit of custom engineering, but you sound like a resourceful sort of person.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 07-31-2010, 04:40:01 AM
armandh armandh is offline
the winch company may have gone out of business but what about the starter motor manufacturer.
also a possibility that a good auto parts store might know of a good rewind shop
Old 08-01-2010, 05:03:12 PM
Thanks for the help. Since posting I have done some more work. It seems the winch maker does not make the winch any more, nor the motor. There are a bunch of 24v winch motors that won't fit, but by th time I try and rewind the armature I think I'm going to be better off ordering a basic winch motor and modifying the mount to fit this winch.
I did see the motor says it "tractional friction" type that I am still trying to figure out, and it's compound wound.
I also notice a regular starter motor armature somunitator has spaces about 3/16" each copper strip that the brush rides on. This aramture has about 3 times as many spaces. Very fine work. I don't think I could fix it even if I had the parts and time.
Also it looks like there was a brake on the back of the motor that might have failed and that is what caused the winch to lock up and burn up. Since the winch has a worm gear in it I think I can leave the break behind.
Anchor windlass failure
The anchor windlass motor burned up.
Kind of on the spot.
Anybody know what winch or motor this is? I need to know as I have to buy a new motor.
Dumping all our 300ft of 1/2" chain into the rocky bottom.
By the way this winch and motor are French by Leroy Somer. They have since given up on winch making.
The Following User Says Thank You to yachtwork For This Post:
Old 08-01-2010, 06:08:24 PM
Leroy-Somer is a division of Emerson. According to their website, they still make DC "brake motors" for mooring windlass/anchor applications. Of course, one should not always believe everything seen on a webpage.
Old 08-01-2010, 06:56:38 PM
Rich Mc Rich Mc is offline
Ramsey automotive winches are available in 24 volt units, maybe you could get the motor only as a repair part.
http://www.ramsey.com/
Old 08-01-2010, 11:23:18 PM
Great info on this site. Thanks for all the help. I learned a lot in the last couple days. One thing is just getting the name of the part I need.
Thanks again to all the respondents.
Scott
Rewind or Replace? mylesdw Generators & Motors General Discussion 105 08-05-2014 11:38:11 PM
Anyone try to rewind a John Deere E armature? comley Magnetos, Ignition Coils and Spark Plugs 1 06-07-2010 09:39:32 PM
Need armature or rewind Tim Rostar Generators & Motors General Discussion 3 05-02-2009 08:31:24 PM
Rotor Rewind panzerwillie Generators & Motors General Discussion 8 02-25-2008 11:51:08 AM
Magneto Coil Rewind? Bill Blackburn Antique Engine Archives 0 07-10-2003 10:59:35 PM
