Has anyone made HEAVY spoked rubber tired wheels?
I Finally found a cart heavy enuf for my 35hp superior, and man this thing looks so correct for an...
this thread has 5 replies and has been viewed 1028 times
Old 01-14-2003, 11:30 PM
Doug Waggonner
Default Has anyone made HEAVY spoked rubber tired wheels?
I Finally found a cart heavy enuf for my 35hp superior, and man this thing looks so correct for an engine cart. Except it has 16'' truck wheels on it. This cart used to be a air compressor trailer for the army. My question is, has anyone made heavy spoked rubber tired wheels? Remember the engine alone weighs 8,800 lbs. I'll post some pics of this cart as soon as i bring it home. Thanks
Waggonner Engine Works
Old 01-14-2003, 11:36 PM
Tanner Remillard
Default Re: Has anyone made HEAVY spoked rubber tired whee
Try finding an older, pull type combine. They have heavy spoked wheels with Tires on them, the only thing is that there about 5 feet tall. Maybe a little big for what you want. They are all over in my part of the country.
Old 01-14-2003, 11:40 PM
Tanner Remillard
Just another thought, the front wheels off of a older tractor. There are alot of them that are spoked with tires. And just a little smaller than them combine wheels
Old 01-14-2003, 11:55 PM
Doug Waggonner
Yea I've thought of spoked tractor wheels, but I dont know how about going about attaching them to these hubs?
Old 01-15-2003, 08:21 AM
Bob Sanders
How about Ford Model A rims, just change the spindles....you can get them at alot of places on the web. Bob
Old 01-15-2003, 01:24 PM
Rob Charles
Hi, You can make a round disc to bolt to the hubs as the wheels do now.find a pc of well casing that will go over the plate and hub so it is in the middle.The well casing could be 5 or 6 inches long.Weld the plate into the well casing.You now have something to weld your spokes to.Put the rim or steel ring around that.make spokes and weld them in.You now have a spoked wheel that bolts to a more modern hub.This way there are roller bearings instead of a plain bearing.good luck Rob
Cast iron wheels for heavy engine Eric McKenna Antique Gas Engine Discussion 2 12-19-2005 10:32 PM
Mogul 10-20, Titan, and some Green Rubber tired High Crop Steve Barr Antique Tractors - Old Iron Lugs, Cleats and Tracks 0 12-06-2004 10:15 AM
RUBBER TO STEEL WHEELS SONNY L Antique Engine Archives 8 08-25-2003 06:11 PM
Tired of pick'n Presidents,how about a governor? Gary Rysavy Antique Engine Archives 1 12-08-2000 03:43 AM
