Adjusting valves on a Farmall H
this thread has 3 replies and has been viewed 5670 times
Old 09-05-2010, 05:05:32 PM
Warren Wolf Warren Wolf is offline
Default Adjusting valves on a Farmall H
Hi, I am looking for guidance on how to adjust the valves on an H. What is the clearance and what is the best way to adjust them, engine running or not. Thanks.
Warren
Old 09-05-2010, 10:36:59 PM
Mike in NC's Avatar
Images: 64
Default Re: Adjusting valves on a Farmall H
Warren,
Farmall book says 0.017" HOT, not running. Hope this helps.
The Following User Says Thank You to Mike in NC For This Post:
Old 09-06-2010, 11:06:38 AM
FarmallBob FarmallBob is offline
Images: 1
Here's a quick step by step that works for me:
1 - Loosen - but don't remove - the rocker cover.
2 - Run the engine to normal operating temperature then shut it down.
3 - Remove the rocker cover. For safety pull the center wire from the distributor or magneto (to prevent an accidental start...)
4 - Bar the crankshaft while watching the valves on the #1 (front) cylinder). Stop when BOTH valves are closed and the timing notch on the fan pulley is aligned with the pointer on the gear cover.
5 - Adjust the clearance on both valves on #1 cylinder to 0.017.
6 - Now bar the crankshaft EXACTLY 1/2 turn then set the valves on #3 cylinder.
7 - Give the crank another 1/2 turn (timing notch will again align with the pointer) and set the valves on #4.
8 - Finally give the crank another 1/2 turn and set the valves on #2.
Personally I like to repeat steps #5 thru #8 (two more full revolutions of the crank) to make sure all valves are set correctly.
9 - Finally replace the rocker box and the coil wire and you're done!
Hope this helps...
Old 09-06-2010, 01:11:50 PM
Thank you. That should be what I need. I really appreciate the responses.
Warren
Adjusting brakes on an AC-AB40 Candy T. Antique Farm Tractors 0 08-04-2010 09:58:35 PM
Adjusting flicker points on a DJA AlbertaPhil Onan Generators 2 02-20-2010 03:06:54 PM
Adjusting points Brent Duxbury Maytag Engine Collectibles 1 11-22-2009 11:13:55 PM
Piston Valves / Slide valves - Preferences? ListerDiesel Steam Stationary Engines, Traction Engines, Steam Boats 3 03-25-2008 09:49:00 PM
Adjusting Volts/Hz Weinerneck Onan Generators 12 02-20-2008 08:25:09 PM
