Steam Engines
Pyle National Turbine Generator
this thread has 11 replies and has been viewed 5031 times
Old 09-27-2010, 10:16:31 AM
Jon Rozevink's Avatar
Jon Rozevink Jon Rozevink is offline
Engine Buyer
Photo Pyle National Turbine Generator
Here are some pictures of a small Pyle National steam turbine generator I aquired after some horse trading the other day. From my limited research it seems that these were used on locomotives for lighting. I think it would be neat on a traction engine also.
The Following 3 Users Say Thank You to Jon Rozevink For This Post:
Old 09-27-2010, 10:52:51 AM
GaarScott GaarScott is offline
Default Re: Pyle National Turbine Generator
Jon,
I believe the 32 CC Reeves at the NTA show has this style of steam turbine generator on it powering its front headlamp. Beth, am I right on this?
Lawrence
The Following User Says Thank You to GaarScott For This Post:
Old 09-27-2010, 12:59:37 PM
PTraubert PTraubert is offline
eMail NOT Working
I have had two like yours and have never seen one missing the brush tension springs. This is unfortunate since these are quite a curiosity at steam shows when running. They are quite robust as a rule. You could try rolling your own springs or searching the net for persons associated with the steam tourist railroad community. To test the basic electrical integrigty of the unit, connect a 12VDC source accross the brushes, if good the armarature will rotate in the direction it is supposed to.
Patrick
The Following User Says Thank You to PTraubert For This Post:
Old 09-27-2010, 02:05:25 PM
Engine Buyer
Hi Patrick
Thanks for writing. I am not to worried about the springs, a friend of mine can make them I think. I have a couple springs that fit it, I just need some better looking ones made
Jon
Old 09-27-2010, 04:08:07 PM
Brian Manning Brian Manning is offline
Backshop Enterprises form Wheatridge, Co, has all the parts available for most of the Pyle National dyno's as well as rebuilt ones on the shelf ready to go.
Brian M.
The Following 3 Users Say Thank You to Brian Manning For This Post:
Old 09-27-2010, 07:39:15 PM
Beth V's Avatar
Beth V Beth V is offline
Yes, our 32 Reeves has one. We have the light bulbs under the canopy and the headlight out front (my brother made from scratch.)
Davide Lorenzone took these nice photos of it under steam/light!
Beth
The Following 2 Users Say Thank You to Beth V For This Post:
Old 09-27-2010, 07:49:27 PM
Engine Buyer
Thanks for the info Brian, I called the company and I have some springs on the way. Those are some neat pictures Beth, it looks like the turbine uses a lot of steam.
Old 09-27-2010, 07:53:38 PM
Zachary Rukstela Zachary Rukstela is offline
Images: 30
They're great units mos def. 32V 16amp 550watts. They are steam hogs for sure, we built a muffler for ours to cut down on the high pitched whine, the muffler did not affect performance. We run a 100watt bulb for the headlight & everything else (gauge, glass, undercarriage lights, etc.) are 25watt bulbs.
32V is apparently quite common on sailboats, we order our bulbs from a sailing supply outfit online.
Enjoy!
The Following 2 Users Say Thank You to Zachary Rukstela For This Post:
Old 09-27-2010, 07:56:01 PM
Beth V's Avatar
Jon,
Good question. I've never inquired as to how much steam it uses! I'll have to ask.
Dad had purchased it long before he bought the Reeves and it just seemed to be a good destination for it.
Saunders have one on their 24 Port Huron also.
Beth
The Following User Says Thank You to Beth V For This Post:
Old 09-27-2010, 08:10:03 PM
Images: 30
Steam consumption varies based on how much you load up the dynamo. When we're running just the 25watt bulbs then switch on the headlight, the dynamo bogs down. I believe it's important to ALWAYS have a load on the output side. Efficiency do not appear to have been a major concern (remember these units usually sat on the top of the locomotive cab or near the cab). Our unit came with KSW's 1920 Case 40HP, I recall our mentor claimed that the consumption of the dynamo was nearly as much as the main engine! I've never run the numbers but I will say that when I've let the pressure climb close to the safety and I wanted to eat up a bunch of steam quickly rather then lifting the pop valve, our Pyle National dynamo was more then happy to help out.
The Following 3 Users Say Thank You to Zachary Rukstela For This Post:
Old 09-27-2010, 08:45:30 PM
Tom Cwach's Avatar
Tom Cwach Tom Cwach is offline
My 75 Case has one on it. The engine spent most of its time in a sawmill and I believe it was used for lighting in the mill.
The Following User Says Thank You to Tom Cwach For This Post:
Old 09-28-2010, 08:20:59 AM
KramerRoadLocomotive KramerRoadLocomotive is offline
We also have one on the Roadlocomotive. We use it many evenings when out on the road after dark. We have also wired for trailer lights such as when we pull the calliope.
The Following 2 Users Say Thank You to KramerRoadLocomotive For This Post:
Info needed for a Pyle National X-2 steam turbine generator James L Steam Stationary Engines, Traction Engines, Steam Boats 4 10-16-2008 08:59:11 PM
Need help with a steam turbine David K Steam Stationary Engines, Traction Engines, Steam Boats 5 01-21-2008 11:09:45 PM
INFO WANTED ON GAS TURBINE GENERATOR Denny Foster Antique Engine Archives 3 01-25-2004 11:44:55 PM
Moon Turbine Generator Allan Miloff Antique Engine Archives 0 03-29-2000 06:38:41 PM
Moon Steam Turbine generator Allan Miloff Antique Engine Archives 0 03-18-2000 06:45:49 PM
