Remove an Onan 5.0 BGA-3CR from Winnebago?
this thread has 18 replies and has been viewed 5874 times
Old 10-09-2010, 03:42:03 PM
gtj811 gtj811 is offline
Default Remove an Onan 5.0 BGA-3CR from Winnebago?
I've been offered an Onan generator 5.0 BGA-3CR/160204 that is in a Winnebago Brave motor home about to be scrapped. How do I remove the unit? Does the generator floor plan drop out? I'd like to grab this generator and set it up for home emergency use. Is it worth the effort? Looks complete and I was told it worked when parked a few years back. The motorhome is from the 80's.
Old 10-09-2010, 04:01:58 PM
bbuchorn bbuchorn is offline
Default Re: Remove an Onan 5.0 BGA-3CR from Winnebago?
From what little I have learned the R/V generators are eather Drawer units or drop out. You will have to look and see how it is installed. My advice is try and get all the wiring , and if it is set up that way get the remote start panel and as much of its wiring also. Get some help as these things are compact and heavy. If it is a drop out unit you will need a good jack to lift it up while you unfasten the mounts. If it looks to be in good shape, and someone is giving it to you it is definately worth the effort. They can be mounted on a good garden wagon and a box built around them for quiet running. If the muffler is good grab it also, you'll need it too. Good luck on your great find and keep us posted . thanks BB.
The Following User Says Thank You to bbuchorn For This Post:
Old 10-09-2010, 04:28:33 PM
RETCPO RETCPO is offline
By all means grab it! As BB said if it is free even better. Get any manual that might be in the RV about the Generator (long shot I know, but if you do not look…)
And you are looking at a 5KW, 60 hertz, 120/240 volt, single phase generator.
Great score, get it before they find out what they are giving away.
Keith
The Following User Says Thank You to RETCPO For This Post:
Old 10-09-2010, 05:07:35 PM
Thanks for the quick response. It appears to have two 110v plugs. Can I wire it for a 240v well pump? Looks complete and about 300 lbs. The jack is a good idea. Gregg
Old 10-09-2010, 05:24:54 PM
Isaac-1 Isaac-1 is offline
Yes to the well pump assuming of course it is not too big for the generator, most residential well pumps would work fine on a 5KW onan, the -3C voltage code means it supports 120/240
The Following User Says Thank You to Isaac-1 For This Post:
Old 10-15-2011, 07:39:26 AM
It's taken a year to get owner to agree to scrap the RV and let me have the generator. I'm supposed to grab it tomorrow and then the restoration will begin. The RV is filled with junk and I'm hoping to grab the remote start and muffler too. Our plan is to use a bob cat with forks to place under the pan and then cut the 4 bolts off after removing the fuel line, wiring and exhaust.
Old 10-15-2011, 08:22:28 AM
jms180 jms180 is offline
It is a good find. Most RV gen sets have very little run time on them. Onan gen set were bult to last. I work at Onan in Huntsville Alabama for 23 years.
Old 10-15-2011, 08:24:50 AM
GTJ811
Mice LOVE generators!!!
They build homes or condos in them!
Once you have possession on this unit clean it inspect it and with the help of the guys of this board you will have a great unit.
Remember post a full make model and serial number then the resident smart guys can give you any advice and PDF manuals.
As has been posted before get everything you can that is associated with this unit.
Keith
Old 10-15-2011, 10:00:24 AM
I bought a 6.5 kw verson of that genset that had been removed from a motorhome with a cutting torch.
On this one, there is a piece of channel that runs from front to back and they simply cut all the wires and cut that channel off at both ends in a handy spot.
Pete Stanaitis
Old 10-15-2011, 07:05:49 PM
Old Style Old Style is offline
gtj811
Like others have said. Try to acquire as much of the original wiring as possible; if not the complete loom at least mark and save the connectors.
Welcome jms180! Always good to have another original Onan man on-board! Bet you have seen many changes over those 23 years I'm just learning but enjoy this board very much! Many great people sharing their knowledge!!!
Old 10-16-2011, 05:00:49 AM
Thanks for the advice. My hope is that the mice moved into the vacant camper and decided to leave the generator alone. Nothing makes a bigger mess than these critters. The original owner of the camper seemed to take decent care of it and even repainted the generator some years back. We may cut out the generator door area and then the four bolts holding the floor pan and lower/lide the unit out. I'll then trace the harness back to the control panel and remove the controls. Sounds like a good plan on paper at least!
Old 10-22-2011, 05:10:48 AM
Took a few hours and the bobcat but I got the generator out of the camper. Had to cut the front of the camper wall near the generator and then 6 bolts holding the pan up. Could not get far enough into th camper to save the internal controls or find any paperwork. Got the unit home, slid onto a picnic table to look at it and the table collapsed just as my wife pulled into the driveway! I've since put it on a furniture dolly and slid into the shed. Last night, I changed the oil, looked at the plugs, hooked up an outboard gas tank and she cranked right over and fired up. I had to cut the muffler off and need to reattach it. She generates power but is running a bit rough. Looks like the carb is leaking gas and has been for a few years based on the grime on the manifold. Is a carb rebuild really $70 for the kit? I will post some photos later this morning. I'm inspired with the restorations photos already posted on the site. Who do you suggest for the carb rebuild kits?
Old 10-22-2011, 07:53:50 AM
David C David C is offline
If you are real carefull when you pull the carb apart, you can reuse the top gasket. The carb probably does not need any parts, just a cleaning. I am cheap so always try the cheap route (sometimes not the best) first. If that fails, its time for a kit.
David C.
The Following User Says Thank You to David C For This Post:
Old 10-22-2011, 08:40:07 AM
Photo Re: Remove an Onan 5.0 BGA-3CR from Winnebago?
Here's the front and the side view of the unit.
Old 10-22-2011, 09:28:28 AM
Notice some of the cooling shroud is missing. Don't run it too long.
Old 10-22-2011, 10:15:30 AM
MBB MBB is offline
I believe I saw some sheet metal parts for it on ebay.
Old 10-22-2011, 03:18:20 PM
I took the side shroud off to clean the dust off and got another piece that I don't know where it goes. It's as wide as the top. Will need to post a photo of the mystery tin next.
Old 10-22-2011, 06:01:19 PM
If it is the same width as the top, I will guess it is a front heat sheild that goes on the front, covering the exhaust.
Old 10-27-2011, 07:47:48 PM
Thanks for response. Indeed it fits over the pipe off the manifold. Got the $60 carb kit today and am looking in the box for my change! Will try and finish the rebuild this weekend and see if it improves the shaking of the twin cylinders. If not, do I need to check the valves?
Onan 2.8KV Teardown to remove carb - help! Orie Onan Generators 1 08-06-2009 06:54:27 PM
Why is it Best not to remove Flywheels? DerekC Antique Gas Engine Discussion 5 03-05-2008 12:42:40 AM
Best way to remove J.B weld? JKWidener Antique Gas Engine Discussion 12 09-14-2007 10:08:27 PM
Red Devil and Winnebago Chief Don Siefker Antique Engine Archives 1 11-25-2004 11:05:55 AM
Red Devil and Winnebago Chief engines, information Don Siefker Antique Engine Archives 0 09-08-2002 03:16:09 PM
