| Antique Tractors - Old Iron Lugs, Cleats and Tracks Photos and information about antique steel wheeled farm tractors. This is where to find the heaviest of Old Iron. |
Gas Traction Big 4 from Blomgren EstateWe are currently working on the Big 4 chassis that was purchased from the Morris Blomgren estate....this thread has 770 replies and has been viewed 168429 times
#61
That's pretty awesome! LOL at John Deere remark!
The Following User Says Thank You to Brasherman:
#62
On November 19, 2010 I made a trip to the foundry in Rice Lake, Wisconsin to pick up various parts for the Big 4 tractor. In this picture are some of those parts: steering chain winder clamps, starting crank, two halves of the water pump, governor mount, governor adjuster, spark plug tube support and clamps, clevises, throttle casting, spark advance casting and lever, crankguard/step.
The Following 22 Users Say Thank You to Allan Severson:
#63
Over the past weekend I worked on a set of pistons for a Big 4 engine. I have all the lathe work done and still have to put the wrist pin hole in and machine the inside bosses.
The Following 37 Users Say Thank You to Allan Severson:
22advance, baker maker, Bill(BC), Brasherman, Brian Flatmoe, Brothers Clemens, Bruce Flatmoe, Craig A, Don Selmer, Ed Bezanson, German George, glenw, Jeff Blaney, Jim Anderson, Keith Bryan, Ken Majeski, Kent McMakin, Kevin Roth, Lyle S, Malcolm Robinson, Marcel P, Mark Schleppi, Marshal Reysen, Mike Harmeling, Mike McKnight, OTTO-Sawyer, Paul Roidt, Phil Johnson, RandyF, Roger Byrne, S.Simons, split51, Steamrguy, Tom Madden, Tom Wahl, Tony B., Tony Thompson | ||
#64
Today I worked on the rubbing rolls, bracket and pins for the steering stops for the Big 4 tractor.
The Following 15 Users Say Thank You to Allan Severson:
#65
This past weekend we worked on the master pinions that Morris had bought many years ago. We built the teeth up and remachined them for the purpose of recasting new ones.
The Following 20 Users Say Thank You to Allan Severson:
#66
Last Saturday we picked up the aluminum piston castings at NRB Foundry in St. Charles, MN. The attached picture shows the aluminum pistons. Also attached is a picture of the finished cast pistons, bearing caps, and wrist pins ready for Bruce Flatmoe to pick up for his Big 4.
The Following 21 Users Say Thank You to Allan Severson:
#68
We melted down some old pistons to save on material cost. |
The Following 7 Users Say Thank You to Allan Severson:
#69
We have started machining the flywheels on the vertical lathe this week. Attached are pictures of the cast flywheel and the lathe it is being turned down on.
The Following 31 Users Say Thank You to Allan Severson:
A Martinson, Andrew Yeary, Brasherman, Brian Flatmoe, Bruce Flatmoe, Buzz, Chris Austin, Christophe35, David Parfitt, eblinga, FWurth, German George, glenw, Jan4CMF, Jim Anderson, Kevin Roth, Kurt Kocher, Lyle S, Malcolm Robinson, Marshal Reysen, Mike Harmeling, Mike McKnight, OTTO-Sawyer, Paul Roidt, Randy Reysen, Roger Byrne, Ron Vance, Scott Hartz, Steamrguy, Tanner Remillard, Tony B. | ||
#70
We are just finishing one of the four flywheels we are working on for the Big 4 tractors. Here are pictures of the finished one.
The Following 25 Users Say Thank You to Allan Severson:
Andrew Yeary, Bill(BC), Brian Flatmoe, Brothers Clemens, Bruce Flatmoe, Chris Austin, David Parfitt, German George, glenw, Keven Withers, Kurt Kocher, Lyle S, Malcolm Robinson, Marcel P, Mike Harmeling, Mike McKnight, Mike T, OTTO-Sawyer, Roger Byrne, S.Simons, Scott Hartz, Steamrguy, Tanner Remillard, Tony B., xplor | ||
#71
Are you going to try and balance the flywheels before putting them on the crankshaft or maybe after and balance the assembly? Or do you think it won't be an issue?
The Following User Says Thank You to Titan1020:
#72
My plan is to balance them as an assembly. There is a place in Owatonna Mn. (Midwest Balancing) that should be able to handle this. It probably wouldn't need to be done, but I want to be sure it is right.
The Following 3 Users Say Thank You to Allan Severson:
#73
That makes a lot of sense to me to do it as an assembly. It sure looks like you're doing everything else right with this engine. Very impressed with your work!
#74
Hi Allan,
How many hours (rough estimate) do you think you will have into a complete motor? Great photos of the actual machining and finished parts! Bubbles |
The Following User Says Thank You to Bubbles:
#75
Looks like I have a little 'catch up' reading to do.... as I kind of lost track of this thread for a while.
Impressive work. Thanks for providing the pictures and information. |
The Following User Says Thank You to OTTO-Sawyer:
#76
As far as hours, I don't even want to think about it. Just doing one step at a time. I tell everybody it will be done by the 4th of July, but i'm not giving a year.
The Following 6 Users Say Thank You to Allan Severson:
#77
We just got a new dealership sign made for our Big 4. It is double sided. It seems like we could be a dealership with all the various parts in our shop.
The Following 24 Users Say Thank You to Allan Severson:
#78
Top notch again Allan!!!
#79
What a hell of a project! There are not many people who buy a tractor without an engine who think, O the engine I can make by myself.
When you have the right tools, you can make everything. Keep going with this fine project and the tractor will be rescued for the future. Gerrit |
The Following User Says Thank You to oldjdinterest:
#80
Sign looks great, work on the engines looks great! I'm just constantly amazed at the scope of work you're doing, and the professionalism of it. Keep up the good work! Mike |
The Following 3 Users Say Thank You to Mike McKnight:
| Morris Blomgren 3 day auction | QuickJ | Live Auctions of Engines, Tractors and Old Iron | 50 | 01-22-2011 07:07 PM |
| Kreiner estate Plymouth NY | SteveK | Live Auctions of Engines, Tractors and Old Iron | 2 | 10-01-2010 12:35 AM |
| Blomgren Auction-Steam & Antique Tractors | Jim Friedrich | Antique Tractors - Old Iron Lugs, Cleats and Tracks | 1 | 09-07-2010 10:52 AM |
| Estate sale in Montrose, Mi | Craig A | Live Auctions of Engines, Tractors and Old Iron | 0 | 02-14-2009 09:43 PM |
| Wilson Estate Auction | John Zalabak | Antique Engine Archives | 2 | 11-10-2003 07:19 PM |
