| Maytag Engine Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm. |
Maytag 72 D twinHi just got my 72D got good gas firing ok just won,t start help me out someone please Bob:shrug:this thread has 2 replies and has been viewed 906 times
If you fueled it with 16 (gasoline) to 1 (30# weight non-detergent oil) mixture and the engine doesn't want to fire, the likely suspect is the fuel check valve located in fuel tank.
Does the engine have air cap? The engine will not start if the air cap is missing. See the following videos on starting a Maytag Model 72 (note the adjustment of the air valve cap) http://www.youtube.com/watch?v=EXWPNmM6Lzc http://www.youtube.com/watch?v=ONc5e...eature=related |
The Following User Says Thank You to Francis:
Spark firing ok in the open air? Firing in the open air is not the same as under compression with a gas-oil contaminated compressed air mixture. Spark can still be the issue and very likely could be. Along with a dozen other things. Bad wires, bad plugs, dirtly points (This is a whole nuther issue, what most people call clean points I call a mess.) Unfamiliarity with points causes many a issue. Also several internal issues will keep you from running. But lets make sure you have all the external issues covered first before we start dissassembling. When you do I agree with Francis check the check valve. But this is an easy diagnosis to check. Prime the engine, Pull the pipe plug out of the top of the crank case, dribble in a tea spoon to a table spoon of gas oil mix plug it back up and try it. If it fires runs then dies then check could be at fault or the governor. If it does not fire then examine the ignition again. Maytag Mark
The Following User Says Thank You to Mark Shulaw:
| Twin Maytag | antiquecarman | Maytag Engine Collectibles | 7 | 03-03-2010 08:40 AM |
| Maytag Twin | L Steiner | Maytag Engine Collectibles | 7 | 04-19-2007 02:17 PM |
| Maytag twin | Kent VanSickle | Antique Engine Archives | 1 | 12-07-2003 06:49 AM |
| Maytag Twin RPM | Randy Peterson | Antique Engine Archives | 6 | 04-23-2002 09:56 AM |
| Maytag twin cyl | Alan James | Antique Engine Archives | 2 | 01-18-2002 11:27 PM |
