Kohler Generators
Service manual for Kohler 7.5 C 62 TP5045 with a l654 engine
this thread has 2 replies and has been viewed 3442 times
Old 10-20-2010, 10:13:57 AM
rohifoundation rohifoundation is offline
Default Service manual for Kohler 7.5 C 62 TP5045 with a l654 engine
There are several posts that include service manuals for various older Kohler models but I did not see the specific one that I have. I am looking for
Model 7.5 C 62 106123 A 3.4
L654 4 cylinder engine
Fairbanks-Morse Magneto
CW Type 20
FM X4B44A
I have the parts pdf but not the owners or service manual.
I am needing the specifications for timing the engine and torque settings. I also am needing information on the generator and its brushes.
If there are other manuals that overlap (use a l654 engine) that would be helpful as well.
Any help would be greatly appreciated.
Scott
Old 10-21-2010, 08:46:34 AM
K D Redd K D Redd is offline
Default Re: Service manual for Kohler 7.5 C 62 TP5045 with a l654 engine
To time the engine with this type of magneto, you want the impulse coupling of the mag to trip when the piston on what ever cylinder of the engine the mag is fireing at or a little after Top Dead Center. This way if you must hand crank the engine, it is less likely the engine will kick back against the crank. The needed running advance for the engine is built into the impulse coulping which does not operate at engine running speed. I like to set the point the couplling trip a little after TDC because I DO NOT want a chance of a busted hand, wrist, arm when hand cranking.
Kent
Old 10-04-2011, 05:35:08 PM
LynnP LynnP is offline
I have the 7.5R62, ser#161068, Spec.#106286-A62N. It is a propane powered standby generator for a communications tower. I see you list service manual TP5045 which I have in .pdf form. This is the parts list for several 7.5 series gensets. What is the fuel for your generator? Where did you find the engine information label? I also have the service manual for the 7.5R which is the marine version.
Ttyl,
Lynn Peters
Scored a L600/L654 Service manual Helmar Kohler Generators 12 02-27-2014 08:56:53 AM
Kohler service manual Robert Vanderslice Kohler Generators 2 05-22-2010 10:14:13 PM
Kohler service manual wanted tim sly Kohler Generators 7 08-02-2009 11:15:01 AM
Need Service Manual for Kohler 7cm21-RV RainmakerBob Kohler Generators 2 09-11-2005 12:54:24 AM
