| Antique Gas Engine Discussion Meet collectors of hit and miss engines, ask questions about collecting, restoring and showing antique flywheel engines. |
John Deere Model EI have a model E that I have taken the piston out of and cleaned up and now I have a bit of a...this thread has 6 replies and has been viewed 897 times
I have a model E that I have taken the piston out of and cleaned up and now I have a bit of a question. Due to my lack of paying attention..... I dont know in what direction the piston goes back it. There is a groove in the piston behind the rings that goes almost half way around the piston. Does this groove go on the bottom of the cylinder or the top? and.. What is this groove for? Oil to lubricate the cylinder?
That groove is the oil slot, and it goes on top.
Also the bumps and oil hole at the end on the con rod on the gear side if you needed that information as well.
Chris from Washington (the state)
Thanks a lot, That really helps! Now I can get it back together!
Another question.. what should I torque the head and rod taps to? Is there a spec?
No spec, Just snug them down fairly tight, the rod bolts normally use a jam nut as well to ensure nothing comes apart.
OKay thanks!
A Atheist will never be able to say, "I told you so!!" More engine movies can be seen at: PILEOFIRON
| John Deere Model B Help | trashman6062 | Antique Tractor Talk | 10 | 09-24-2010 05:58 PM |
| John Deere Model 12 saw | akretowicz | Garden Tractors / Mowers / Scooters | 4 | 12-02-2008 11:31 PM |
| My John Deere Model 12 | akretowicz | Garden Tractors / Mowers / Scooters | 0 | 11-27-2008 07:48 AM |
| John Deere model -E-1 1\2 hp | Jerry B | Antique Gas Engine Discussion | 11 | 02-12-2008 02:02 AM |
| John Deere Model E | Stevie | Antique Engine Archives | 1 | 08-17-2003 11:00 AM |
