Any 1929 Chevrolet experts?
this thread has 8 replies and has been viewed 5234 times
Old 11-13-2010, 02:58:46 PM
Avery22x36 Avery22x36 is offline
Default Any 1929 Chevrolet experts?
I searched here and didn't find much, I got a fairly complete 1929 Chevy farm truck I am wanting to put my Standard Oil tank on, however, I am missing an engine. I have picked up several Chevy inline 6 engines but they are all different, can someone tell me what years of engines will interchange? I got a very rough 31 also with the steel top and it needs one also, its really junk but it was my Great Grandpa's so that makes it worth restoring to me anyway. Does anyone know of any companys that cater to these old trucks? Thanks, Aaron
The Following User Says Thank You to Avery22x36 For This Post:
Old 11-13-2010, 03:30:04 PM
OTTO-Sawyer's Avatar
Default Re: Any 1929 Chevrolet experts?
Sounds like a great project, but are you sure it takes a six cylinder and not a 4 ?
Old 11-13-2010, 04:17:13 PM
ar2stp48 ar2stp48 is offline
Try google search for a club or forum? I just did a quick search (used 1929 Chevy forum) and found a few choices; one was AACA. Know there is a forum devoted to early Chevy as a friend had a '34 sedan that he found lots of information for. The '34 had a 6 cyl but I do not know the year of introduction or much about the interchange. I think any early 135 should fit though.
If you dont find the group online, I'll get the name and address from my friend on the chevy group he joined.
Good luck with the project. And pictures would look good too.
Old 11-13-2010, 04:57:04 PM
Tom G Tom G is offline
Here's a link to some info on the Chevy 6 cylinder engines.
http://en.wikipedia.org/wiki/Chevrol...aight-6_engine
I'm not sure what engines will fit in your trucks, but if they will fit, I would try to use a 1954 model 235. The 235 has more power, and a much better oiling system. The older engines used dippers on the rods, and didn't oil very well at high RPMs. It was easy to burn out a rod bearing, if you didn't keep the RPMs down.
The later model 235s used a longer water pump, and using them in older vehicles means either modifying the water pump, or moving the radiator forward.
I'd search the web for old Chevy enthusiasts, and see what info they can offer.
Good luck.
Old 11-13-2010, 07:05:56 PM
Terry Welch Terry Welch is offline
My 35 Chevrolet QD grain truck has 205-6 in it. The 35 car had a bigger 6 cylinder. Not sure on the trucks but some late 20's Chevy's had 4 cylinder engines in them.
Terry
Old 11-13-2010, 07:08:33 PM
Junkologist's Avatar
Images: 128
Last year for the four cylinder engine was 1928.
Mike
Check out my engine videos at http://www.youtube.com/profile?user=Cletrac
Old 11-13-2010, 11:27:24 PM
Rick McKay Rick McKay is offline
Aaron,
I believe the correct engine for your truck would be a 194 6 cyl with an updraft carb. If memory serves, they used the large 7/8-18 thread spark plugs like the model a ford.
Rick
Old 12-02-2010, 12:46:13 PM
Dale Sorber Dale Sorber is offline
http://www.stovebolt.com
This site is all chevy trucks. You may have to dig for the earlier info, there is a lot of newer stuff. I have done well in the for sale and wanted sections. Good Luck!
---------- Post added at 11:46 AM ---------- Previous post was at 11:40 AM ----------
Here's another site that is more the earlier stuff. A lot of good knowledge is available here. www.vcca.org
Old 12-03-2010, 10:48:45 PM
Jerry Sweet Jerry Sweet is offline
A 194 C.I.D. engine is correct,but there isn't much difference between 1929 through 1936 basic engine,except for a cylinder bore change.they were all 4" stroke and a 3 main bearing crankshaft,and they made a change to a downdraft carburator,but the updraft manifold will fit any of those,if you want it to look original.There was a slight change in the crankcase breather,but it won't be to noticeable(1929 just had two holes in the crankcase,one for the oil filler and another for the breather,the later ones just had one for a combination filler and breather).For 1937 and later they came out with a full water jacket and a four main bearing 3 3/4" stroke crankshaft with a lot larger main and rod bearings.
The Following User Says Thank You to Jerry Sweet For This Post:
Wanted: 194 c.i. Chevrolet 1931 Vetteman61 Antique Autos and Trucks 2 01-19-2010 07:19:40 PM
1932 Chevrolet truck radiator? Philip Allen Antique Autos and Trucks 0 01-03-2010 05:32:18 PM
Free 1932 Chevrolet engine Tom Kilgore Antique Autos and Trucks 1 05-26-2008 07:30:04 AM
Propane Chevrolet C6500 Alltractorman Trucks, Trailers and Hauling for Shows 6 05-22-2008 03:07:19 PM
51 chevrolet truck 25,000 miles OldAgIron Antique Autos and Trucks 7 03-06-2008 09:29:23 PM
