Kohler Generators
Kohler Generator - 4CM21 High Voltage
this thread has 3 replies and has been viewed 2204 times
Old 12-05-2010, 09:10:56 PM
powerleg5 powerleg5 is offline
Default Kohler Generator - 4CM21 High Voltage
Hello, I just acquired a Kohler Electric Plant model 4cm21 with the following numbers 10214A3-44B. It's a 4 KW unit. The guy I got it from said he burn up two air conditioners with it. I did a little maintenance on it like oil change and carb work and she fired right up and ran fine. But the voltage output was 179 volts at idle and on an engine rev the voltage jumped to around 205.
I can see why he lost those AC compressors with that kind of high voltage. I don't have any type of manuals or paperwork on this thing and I really don't know what to check on it to get this voltage down to 120.
Any help would be greatly appreciated and certainly used.
Thanks in advance,
Tim
Old 01-25-2011, 11:15:58 PM
Randy W. Randy W. is offline
Default Re: Kohler Generator-4cm21 High Voltage
Thanks in advance,
Tim
Hi Tim,
Check your engine speed. Engine govenor should hold engine RPM at 1800+/- 10%. At 1800 RPM, alternator should produce 120 volts.
Old 01-26-2011, 11:50:22 AM
Thanks for the info Randy. I was finally able to dig around deep enough and acquire the info on rpm = voltage regulation. She purrs like a kitten now and produces a nice steady voltage around 119 to 124 under a pretty good load.
Now my next task is building a frame for it with springs attached to compensate for the vibration. With it just sitting on blocks or whatever it will tend to walk off whatever is holding it and this thing weighs a ton. My plan is to build a frame with wheels for easy transport to where ever I need quick and quiet power.
I will say one thing about Kohler Engines. They are stout. I had a Kohler on a John Deere Mower and you could bush hog the field with that thing and not bog it down.
Old 02-01-2011, 10:09:29 AM
marcus320 marcus320 is offline
Default Re: Kohler Generator - 4CM21 High Voltage
I have the 4-5ckm service manual, the 4-5ckm operators and install manual, and the 4.5 RV service manuals on 3 pdf files which I can e-mail. let me know. marcushenning@zillacomm.net
Manual Needed: Generator 4CM21/Kohler K321EP leonaiz2 Kohler Generators 2 07-14-2013 04:02:44 AM
Kohler Model E DC Generator voltage is to high Dale C Kohler Generators 8 02-26-2011 10:54:31 AM
Help Kohler 4CM21 Generator No Spark handiman38 Kohler Generators 1 09-08-2010 12:47:18 PM
Kohler 4CM21 low voltage osiyo Kohler Generators 4 06-29-2009 08:04:43 PM
Kohler Generator Voltage REgulator Failure James Hollifield Kohler Generators 1 06-30-2006 01:35:28 PM
