MEP-002A Low Voltage
this thread has 9 replies and has been viewed 2110 times
Old 12-19-2010, 05:04:19 PM
Onan Onan is offline
Default MEP-002A Low Voltage
I recently acquired an MEP-002A generator and the AC output seems to be low. In the tech manual it states that the output voltage should be between 228 and 252 volts within the full range of the AC voltage control on the control panel. On my unit the voltage is between 194 and 237 volts within the full range of the control. I am using a quality Triplett multi meter for my readings.
Is there another adjustment for this perhaps on the voltage regulator or elsewhere?
Can either be used on this unit as an aid for cold weather starting?
Any help or suggestion would be appreciated
Jerry
Old 12-20-2010, 12:09:26 AM
David C David C is offline
Default Re: MEP-002A Low voltage
Is it running the proper speed? Are you relying on the panel hertz meter or are you using a handheld meter? I would not use ether due to the intake heater and glow plugs that the Onans have. It should start in some fairly cold weather without ether.
David C.
Old 12-20-2010, 08:14:31 AM
David:
I am not using the panel instruments. For the voltage I am using a Triplett multi meter and for the cycle/engine RPM I am using a 60 cycle reed type frequency meter.
Jerry
Old 12-20-2010, 10:31:00 PM
Jerry,
Have you checked the rotating diodes. I had one fail on my MEP-003 and it caused a reduction in voltage, but I don't remember by how much. It has been several projects ago and CRS seems to be kicking in.
David C.
The Following User Says Thank You to David C For This Post:
Old 12-20-2010, 11:55:43 PM
Jim McIntyre's Avatar
Jim McIntyre Jim McIntyre is online now
Default Re: MEP-002A Low Voltage
Can the MEP-002A be set for either 120/240 or 120/208?
Old 12-21-2010, 01:39:03 AM
Isaac-1 Isaac-1 is offline
yes, the MEP-002a can be set for either 120/240 single phase or 120/208 3 phase. (also I think 120V single phase only, and if it is like my MEP-701a it can also do a strange 120V 3 phase mode)
Old 12-21-2010, 07:05:29 AM
David:
No,I have not checked the diodes. Where are they located?
Jerry
Isaac:
The reconnection switch is in the correct position.
Jerry
Old 12-21-2010, 11:39:29 PM
I see. By "correct position", you mean 120/240? That being the case, what are you worried about? 237 V is plenty close to 240 V for all practical purposes...
In my experience a bad rotating diode causes a major voltage loss.
Regarding ether, Onan, in their manual for the DJ series of genset, has a specific warning (in Bold Italic letters) stating ether can cause engine damage. This is consistent with my general rule-of-thumb, that ether is not for Diesels with preheaters...
Ether will undoubtedly help cold starting, but at what cost is the question.
Old 12-22-2010, 11:01:01 PM
Jerry,
Check you email for a manual.
David C.
Old 03-17-2011, 07:39:55 PM
NYDieselHead NYDieselHead is offline
Good manuals here for MEP002A and MEP003 and J-Series Onan engines and gensets:
http://www.scribd.com/Tereeeee/shelf
http://www.greenmountaingenerators.c...--support.html
MEP 002A looking for suggestions harryg Military MEP and Aircraft Gen-Sets 14 07-17-2012 05:15:45 PM
MEP-002A Looking for part lococoyote Military MEP and Aircraft Gen-Sets 7 11-25-2011 11:11:53 AM
MEP-002a Jim Kinler Military MEP and Aircraft Gen-Sets 3 03-17-2011 07:32:16 PM
MEP-002A AC voltage hunting / fluctuating Jim Kinler Military MEP and Aircraft Gen-Sets 0 01-16-2010 05:33:04 PM
Are MEP 002A EMP hardened? Joe Dupont Military MEP and Aircraft Gen-Sets 8 05-04-2009 07:55:31 PM
