| Multi-Cylinder Stationary Engines and Power Units Waukesha, Buda, Climax, LeRoi and others. |
Wisconsin TDF, need some helpHello everyone, i have a wisconsin TFD that im currently overhauling and for some reason i cant get...this thread has 1 replies and has been viewed 897 times
Hello everyone, i have a wisconsin TFD that im currently overhauling and for some reason i cant get the oil pan off. I have removed all 10 bolts, 8 on top and 2 underneath and it still wont budge. The second problem im having is with the hand operated clutch, i removed the 4 bolts fastening it to the engine and it only pulls off about 3/8"? Anyone who may be able to help would be great. Thank you.
Hi
Do you have the manual? You have to remove the cover on the top of the clutch housing in order to get the operating fork free from the clutch “Ball”. Once the housing is off there are a couple of bolts close to the engine that you have to remove from the clutch ”Ball” then pull it off. I don’t have the complete manual for this engine however I do have the parts manual in a PDF file but it doesn’t show the clutch. I do have a single cylinder repair manual that shows the clutch. If you would like I can E-Mail them to you. Use the single cylinder manual for the clutch only. I don’t think the parts for the clutch are the same either but it has a breakdown and instruction on how to remove and install the clutch. The parts manual shows 6 short and 2 long bolts for mounting the engine base. It sounds like some one used some sort of glue or gasket sealer when it was last installed. Phil P PS: PM me you E-Mail address don’t post it or a phone number on the forum. |
| Help! I have a Wisconsin... | JIMnWV | Wisconsin Engines | 9 | 04-22-2010 12:02 AM |
| Wisconsin BKN | Jim M. | Wisconsin Engines | 1 | 04-12-2010 01:23 AM |
| Wisconsin BKN | Jim M. | Wisconsin Engines | 3 | 04-04-2010 08:01 PM |
| Wisconsin AEH Same as AHH? | JD Gimpl | Wisconsin Engines | 2 | 03-24-2010 10:15 AM |
| Wisconsin AKN: Before and After | Jimmy | Wisconsin Engines | 6 | 04-01-2008 09:57 PM |
