Generac Generators (SEARS, etc.) Restoring, maintaining and operating Generac generators.
Rewiring Generator from 230v to 110v
this thread has 6 replies and has been viewed 4516 times
Old 01-09-2011, 01:38:24 PM
JaimeRusso JaimeRusso is offline
Default Rewiring Generator from 230v to 110v
I just purchased a Lambordini 6LD 325 generator. It is wired for 230v but I want to convert it to 110v. The current wiring configuration is one leg with a green wire and a yellow wire and the second leg with a black wire and a red wire. It also has a green wire that is ground.
Old 01-10-2011, 10:13:24 AM
Descentman Descentman is offline
Default Re: rewiring generator from 230v to 110v
This sounds like a single phase generator already. If so, it may be a 115/230 (aka 110/220 - 120/240) already - 120/240 is usually the standard. If you're not familiar with working with electricity, I would recommend calling a friend or an electrician, because it can be VERY dangerous and can KILL YOU. That being said, your four wires (not including the ground) are the two legs of your unit one wire for each leg is neutral the other is hot. Depending on how it is wound, you may be able to make it 115 only, but I am unfamiliar with that particular model and wouldn't want you to risk burning it up. Do you have a need for full power 115 volts?
Old 01-10-2011, 08:36:08 PM
Default Re: Rewiring Generator from 230v to 110v
I am powering a 110v well pump and so only need it for that purpose.
Old 01-11-2011, 11:23:15 AM
armandh armandh is offline
Ive attached the typical single phase connections
CAUTION
wiring for 120 only
is like jumping a car battery
get it wrong and stuff goes bad.
Old 01-11-2011, 01:04:32 PM
Arkie Arkie is offline
You might read through this info and see if any of the guys have a diagram or wiring info for yours!
http://www.smokstak.com/forum/showthread.php?t=46655
Is the water pump motor re-connectable for 230v?
and do you have a electrical tester?
You only get one shot at the correct wiring (phasing of the windings) get the A,B,C,D phasing backwards and it will let the smoke out fast!
Old 01-12-2011, 04:08:48 PM
NON U.S. generators may be only 240 but...
if set up for split 240 then
mark the two connected together B,C then disconnect them [all 4]
with a multimeter on the lowest ohms scale look for resistance
B should only read resistance to the A lead [mark it]
C should only read resistance to the D lead [mark it]
connect as shown for 120 only
I dont know if this is true of most single phase onan
but one I saw has 3 0f the 4 wires comming into the control box via what appear to be feed through capacator studs.
the other wire should always be [N]
Old 01-12-2011, 10:03:24 PM
I used letters rather than numbers because I assume no ID or drawings
you put the letters on
do series first
find pairs with an ohm meter
temp letter the leads
trial connect in the split 240
if you get 120 on each side but no 240 across
switch letters A/B and reconnect for split 240
re test
then you can go to the post 6 above for 120
use all necessary cautions
you are testing lethal voltages.
MEP 4-7 Generator-Rewiring to Delta B.Ikard Military MEP and Aircraft Gen-Sets 6 02-25-2010 01:02:55 PM
Rewiring Onan Gen Set Cruiser Generators & Motors General Discussion 7 02-15-2010 09:59:18 PM
Petters 110V DC 4kW Searchlight Generator ListerDiesel Military MEP and Aircraft Gen-Sets 0 06-03-2008 05:04:44 AM
Rewiring JC/JG 18RR or 4R for 120/240 WmBeyer Onan Generators 4 04-11-2006 08:11:42 PM
Delco 110V Allen L Fry Delco and other Low Voltage DC Light Plants 3 09-28-2005 08:13:44 AM
