Injection Timing on SL1 Lister
this thread has 4 replies and has been viewed 2331 times
Old 01-20-2011, 08:09:08 AM
E27N E27N is offline
Default Injection Timing on SL1 Lister
Got a SL1 off a genset that was running @ 1800rpm I've converted it to variable speed but I'm only wanting to run it @ 900-1000 rpm on an air compressor should I be retarding the injection timing a bit and if so how
cheers in advance
Old 01-20-2011, 09:48:34 AM
Default Re: Injection timing on SL1 lister
Hello E27N,
Presume your SL diesel is much like the later SR and ST etc, in which case the pump timing is set with shims under the pump body. Add shims to retard injection. Would guess that retarding by another 5 degrees would be OK. Spill timing is a bit slow and messy on Listers, so you may get away with some trial and error by loosening the pump and adding a split shim of .005" or .010" under it, and if it starts well and runs with less knock, you are OK. Be sure the pump is tightened to align with linkage so that the rack still moves freely, or it could bolt on you. Think I have manuals with timing figures for ST series at various speeds. Email or PM if these are useful, Regards, Combustor.
The Following User Says Thank You to Combustor For This Post:
Old 01-21-2011, 10:11:14 AM
oldgoat oldgoat is offline
Email NOT Working
If I remember correctly there is no need to alter injection timing on the SL Listers for 1000 rpm but the exhaust tappet clearance has to be increased to 10 thou.
My memory isn't that good I just looked it up in the book inlet 2 thou and exhaust 6 thou below 1200 rpm and at 1000 rpm you are only going to get 2.4hp hope it is enough to drive your compressor
The Following User Says Thank You to oldgoat For This Post:
Old 01-22-2011, 06:49:09 AM
yeah i'm hoping it should be enough grunt I only want to run a kero gun or air blower anything more I'll use the old mans 15cfm
Old 01-23-2011, 09:35:42 PM
Default Re: Injection Timing on SL1 Lister
Hello all,
Hope my previous post didn't lead people astray. Oldgoat is correct in that the pump timing for an SL does not need to change with reduced revs. Forgot they have a pintle style injector which has a delay effect to compensate. It is also correct to set the exhaust valve to .006" cold clearance.
Later direct inject series, ST etc. varied pump timing to suit speeds above 2000 rpm only. Regards, Combustor.
Lister 12/2 30kw koler generator head COOLING The Lister????? mytickets Vintage Diesel and Oil Engines 2 04-12-2010 04:34:18 PM
source for model 50 injection pump timing buttons? peyton Onan Generators 11 09-14-2009 12:45:54 AM
United Kingdom: Lister gears, timing, etc. KidDynamo Vintage Diesel and Oil Engines 14 08-28-2007 03:59:15 AM
Need Lister spill timing help George Andreasen Vintage Diesel and Oil Engines 5 09-30-2006 12:20:09 AM
IHC M 3HP water injection Dave Jennings Antique Gas Engine Discussion 7 04-11-2006 03:40:11 AM
