John Deere B head Gasket
this thread has 14 replies and has been viewed 7590 times
Old 01-25-2011, 04:30:49 PM
bfmco7 bfmco7 is offline
Default John Deere B head Gasket
Im going to pull the head back off my B John Deere after about 10 minutes of running. Something (hopefully the head gasket) is leaking and filling the cylinders up. Does anyone know where I can get JUST the head gasket for this tractor? The problem is that the serial number is 89613. This is under 96000 and the application is only for 2 years. Any leads would be greatly appreciated.
Old 01-25-2011, 04:53:45 PM
John in Maryland John in Maryland is offline
Images: 15
Default Re: B head Gasket
Napa?
J.I.M.
Old 01-25-2011, 05:39:11 PM
mmcdonald mmcdonald is offline
Banner Sponsor
I know Deere has the head gasket seperate(B1307R subs to R521491). Sometimes a head set from elsewhere is cheaper, but a phone call to price JD would be easy.
info@mcdonaldcarb.com
Old 01-25-2011, 06:15:26 PM
John W John W is offline
Default Re: John Deere B head Gasket
NAPA does not have that gasket. However there is a place in Washington that I use for obsolete gaskets. They have (or had if someone has bought it) a Victor number 1. It is called Olson's Gaskets. Here is the contact information:
Olson's Gaskets
3059 Opdal Rd E
Port Orchard, WA 98366, USA
Phone: (360) 871-1207
Fax: (360) 871-0991
Email: info@olsonsgaskets.com
Hours: M-F, 8am-4pm PST
Old 01-25-2011, 07:46:12 PM
Mark Birdeau Mark Birdeau is offline
bfmco7; Did you remember to install the lead washers? They are quite often the reason for leaks.
Mark:
Old 01-25-2011, 07:56:31 PM
Thanks for the information folks.
I tries deere and they can get it for 90 dollars
Yes I installed the lead washes and sealed the studs in the block.
Old 01-25-2011, 10:30:52 PM
Did you check to see if your push rod tubes leak? Iwould take a look at them.
Old 01-25-2011, 10:39:37 PM
Rick McKay Rick McKay is offline
Leaky push rod tubes cause the coolant to leak into the crankcase, not the cylinders. You could be looking at a gasket leak, cracked block, cracked head, or a machined gasket surface on the block or head that needs re-machining.
Rick
Old 01-26-2011, 01:17:51 AM
ronm ronm is offline
Does the block have dowel pins to locate the head? Can't remember if a B does, I know 60 & 620 do, if the head is surfaced, the hole in the head might not be deep enough for the pin. Don't ask how I know this...
Old 01-26-2011, 11:37:14 AM
Yes I checked the push rod tubes before I assembled it, they are fine. And yes, it will cause it to go in the cranks but good thought! I will take all the opinions I can get.
This engine doesn't have pins and the head and block have been pressure checked as well as milled for flat surfaces on both.
Old 01-26-2011, 01:21:42 PM
Well the heads off............
I had water in all four puch rod tubes, and the push rod tubes are solid. There was water in both cylinders... The only thing that it can really be is the head gasket right? I heard through the grapevine that dear head gaskets were junk...
Old 01-26-2011, 03:14:20 PM
Forrest A's Avatar
Make sure that the surfaces are bare metal (Must be clean, clean, clean). Check the flatness of the mating surfaces with a steel rule or the like and for cracks (once clean). (Poor mans crack finder, it wont find internal cracks) Cracks can be found sometimes by laying a magnet on the head surface and then sprinkling iron filings on the surface. If there is a crack the iron filings will stand up on the crack. You will need to move the magnet around a bunch and repeat. Sealer. I prefer to use spray sealer on the surfaces before installing the gasket. Torque the head and then loosen it again. Then retorque the head again. See the chart at the link below for the torque specs. You will need a 150 ft lb torque wrench to achieve proper torque on the head nuts (A clicker is better than a bender...).
http://www.antiquetractors.com/Resea...er/torqspc.htm
Old 01-26-2011, 08:10:18 PM
Thanks for the advice! Anyone else have any install recommendations? I will take all I can get. If this 90 dollar head gasket gets wasted Im going to be a bit bitter at myself. Also, I want to make sure I install it right so if it does fill the cylinders again I know that it is the machine work.
Thanks in advance
Old 01-29-2011, 01:42:13 AM
Which side would you say goes toward the block (not the head?)
Old 01-29-2011, 08:05:10 PM
I don't know if it's right or not but if they aren't marked I always put the rough side to the block. (first picture )
Mark:
John Deere A and John Deere R For Sale (Stuck in the snow!) Gary Biewer Antique Farm Tractors 11 01-25-2011 06:33:52 PM
John Deere W-111 Head specs H.P. Firmin III Farm + Industrial Antiques and Collectibles 1 03-15-2010 06:22:34 AM
John Deere E 1 1/2 hp gasket set Gary55379 Antique Gas Engine Discussion 16 09-24-2009 11:10:55 PM
3 hp M head gasket Al Hettich Antique Engine Archives 5 08-06-2003 11:02:12 AM
John Deere Model E Head Torque Dave U Antique Engine Archives 4 03-26-2003 11:53:33 PM
