Super A Front End Disassembly
this thread has 12 replies and has been viewed 1370 times
Old 02-09-2011, 10:40:37 PM
Jakesut86 Jakesut86 is offline
Default Super A Front End Disassembly
I can't seem to get the pivoting pin apart from the steering housing. Anyone have any ideas.
Old 02-15-2011, 01:31:57 PM
Default Re: Super a front end disassembly
I'm not familiar with that, but the usual line starts with "Bigger hammer...." Is it a dead head, or does it go through and through?
Old 02-20-2011, 03:33:21 PM
Default Re: Super A Front End Disassembly
it goes straight through and i have seen no pins or clips of any sort so i have no idea on how to get this thing apart.
Old 02-21-2011, 01:25:08 PM
Weezer Weezer is offline
I'll be tackling one this week (hopefully). I'll let you know how I make out, and maybe what NOT do do if you haven't got yours out already.......
Jim
Old 03-02-2011, 10:12:59 PM
Ok, Jake, I have mine apart to reseal the steering box. My pin reluctantly came out, but be very careful! You must remove the pinch bolts, they are keyed into the pin. I also used a small machinists wedge to GENTLY spread the pinch part of each end of the castings. Don't go crazy with a large hammer, the casting on both ends definitely won't take that kind of abuse. The tube that is welded to the axle that the pin goes thru is bushed at both ends. The bushings only go in about 1.5 " so that is probably where you're hung up. I would heat the ends of the tube where the bushings are first. Something else you could do is tack weld a nut to the end of the shaft and try turning it, you may loosen it enough, then hammer away...... gently.
Jim
The Following User Says Thank You to Weezer For This Post:
Old 03-02-2011, 10:33:43 PM
awesome thanks alot and is there any way you could send a few pics so i can fully get what your doing if not its cool thanks again
Old 03-03-2011, 12:31:59 PM
Jake,
I haven't had a whole lot of luck posting pics on this site, I'll see what I can do tonight, if not then I can surely e-mail them to you........
Jim
Old 03-03-2011, 05:50:47 PM
Hey thanks man hopefully things work out so I can see what's going on thanks again
Old 03-03-2011, 10:28:03 PM
Ok Jake, here we go........
Old 03-03-2011, 10:31:44 PM
Oh yeah, one more thing. Once you get to reassembly, if you're doing it yourself, DO NOT USE YOUR FINGER TO CHECK ALIGNMENT OF THE HOLE FOR THE SHAFT! Ya know those neat cigar cutters..........Yeah... be careful or get some help.
Old 03-03-2011, 10:57:09 PM
Looks good man but I have a problem my super a has a different front end I have the one where the pin is connected to a bent shaft that hooks the engine block to the bell housing but thanks for all the info man.
Old 03-04-2011, 11:04:02 AM
Sorry Jake, thought they were all the same. The one at Rough & Tumble is the same as mine, so I can't help you. Good luck!
Old 03-15-2011, 11:58:21 PM
It's a heavy duty front end and the pivot pin curves up and mounts below the oil filter hooking to the block and bell housing anybody can help please let me know thanks.
Mag bracket disassembly. Greg Shipley Antique Gas Engine Discussion 2 02-01-2010 08:06:30 AM
F-M governor disassembly highpockets003 Antique Gas Engine Discussion 8 09-22-2009 08:53:51 PM
Farmall Super A front end - tips? tricks? tirediron Antique Farm Tractors 2 03-13-2007 12:03:36 AM
Fm-z, 1.5hp, Governor Disassembly Dave from Omemee Antique Gas Engine Discussion 2 03-15-2005 12:28:46 AM
Disassembly of piston David Showerman Antique Engine Archives 0 07-22-2000 12:19:21 AM
