Ford 8N Transmission Repair
this thread has 7 replies and has been viewed 5794 times
Old 03-17-2011, 08:27:51 PM
international606 international606 is offline
Default Ford 8N Transmission Repair
going to repair and 8n ford transmision. What all needs to be removed before the you do the rear split. Do you need to remove the pto shaft or the pto control lever or do they just slide apart like the front split. Looking for some pointers or tricks before I tackle this one.
Thank You
Old 03-17-2011, 09:09:15 PM
Ray Cardoza's Avatar
Ray Cardoza Ray Cardoza is online now
Default Re: 8n ford transmision repair
from what ive learned the engine needs to come off then the transsmission splits from the rear end. there could be other ways but this is what ive seen so far.
Old 03-18-2011, 07:56:42 AM
Default Re: Ford 8N Transmission Repair
My local library has the complete manual,really good info in there,If they don't have something I need they can get it through a exchange program they have up here.
Old 03-18-2011, 12:43:53 PM
Tractor Supply Stores, TSC here, used to carry the basic repair books on that stuff.
Old 03-18-2011, 01:48:12 PM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
I would split the tractor behind the engine. You have to pull the hood off anyway so that you can unbolt and remove the steering column to access through the top if I remember correctly (that's how it is on my 2N). You can remove the input shaft and countershaft by removing the bearing covers inside the tranny housing on the front (engine side), then slide the shafts out through the holes. The gears just slide off, or you can slide out just far enough to tilt the shaft up and pull the whole thing out through the top cover. What exactly are you trying to repair? A chipped/noisey gear?
Old 03-18-2011, 04:00:13 PM
I shelled the one gear on the bottom shaft in transmission plus missing teeth on another. From what I have heard and read that to change those gears everything comes out of the transmission. But I am also looking into getting a donor tractor and swapping tranny's. The old ford pushed too much snow this winter. I am open to any suggestions If it wouldn't be a tractor that was in the family I would send it over to Bethlehem Steel for a bath in their big tub.
Thank You
Old 03-18-2011, 08:19:33 PM
Jebaroni's Avatar
Seriously, you don't need a donor tractor. Swapping the gears out in these things is really easy. I had never seen the inside of a transmission before and I completely rebuilt mine with little more than a socket wrench and a pocket knife. You may wish to call just8ns.com and see if they have any spare parts they could sell you. Very helpful and fairly priced.
Old 03-22-2011, 06:27:21 AM
wilson Ross wilson Ross is offline
They are really simple to do . But you want to watch all bolt lengths when removing and reinstalling bolts. Thats why my gear got taken out. Owner before me put bolts in wrong one was to long, inturn it knoched a chunk of the gearbox off , dropped in the gears when he went to move the old girl CRUNCH..........Just saying..........
Ford Model T Repair Postcard Dustin D Ehli Antique Autos and Trucks 1 02-10-2011 02:45:41 PM
Ford 9N Hydraulic Pump Repair drofnasd Antique Farm Tractors 3 10-16-2010 10:46:46 PM
1951 Ford 8N tractor rear end repair GWP819 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 06-26-2010 01:28:42 PM
Help I D transmission mechman Antique Autos and Trucks 3 08-24-2007 09:12:57 AM
