Welding Shop
Welding cracks in cylinder
Found cracks in the cylinder on a 6 hp Fairbanks Morse H I am restoring. Two are cracked around the...
this thread has 7 replies and has been viewed 914 times
Closed Thread
Old 04-14-2003, 11:10 PM
Merlin
Default Welding cracks in cylinder
Found cracks in the cylinder on a 6 hp Fairbanks Morse H I am restoring. Two are cracked around the point where the head bolts attach in the water jacket. The other one starts one side of a where the bolt attaches and goes around the ignitor to the other bolt. The cracks are only in the cumbustion chamber, not where the piston runs. The engine was in a fire, but I don't know if that was the cause of the cracks. I would like to weld this. Does any one have any ideas about how to go about this? In total, there is likely about 8 to 10 inches of crack.
Old 04-14-2003, 11:37 PM
Vernon
Default Re: Welding cracks in cylinder
If it was me I'd drill a hole at the end of the cracks. Grind a V in the crack, (both sides if you can), and them get some nickle welding rods and weld it up. The condition it's in, I don't think you can hurt it.
Old 04-15-2003, 01:10 AM
Thomas Winland
Be careful not to warp it though by getting it too hot.
Old 04-15-2003, 01:43 AM
CJ Winslow
A fellow I know has done some welding on cast iron for me. There is a lot of debate on this topic in terms of pre heating and post cooling. He has welded some high stress areas for me (rocker arms, garden tractor axels etc.) and all that he does is pre heat, weld with nickel rod and let it cool on its own without quenching it etc. So far I haven't had one of his welds break on me.
CJ Winslow - the kid with a lust for rust.
Old 04-15-2003, 08:21 PM
Merlin
Thanks. That's what I was thinking of doing, but I thought there may be a better way.
Old 04-16-2003, 09:33 AM
Mark Congden
Merlin...If it were my engine, I'd V it out with a grinder and weld it up with a wire feed welder or mig....weld it with low temp,no preheating or slow cooling...this method works better for me in places that are thin and no/low stress areas like water jackets...Oh by the way...when you're done trying the Nickle rod on thin areas...and have an engine full of "burn through holes"...the wire feed works good to fill in the holes too.....Thank God! Mark Congden
Old 04-16-2003, 10:43 AM
Elden DuRand
I've read about a cold repair process called "metal stiching", where you drill and tap the crack and insert special studs that interlock.
You can look up metal stitching on the Web. Personally, I don't like to cook old iron. Sometimes it ends up in worse shape than when you started.
Take care - Elden
Old 04-17-2003, 12:16 AM
Merlin
I'm not sure how thick it is, but I would think it is fairly thick. Is there any thing special about the wire or the gas for wire welding. Cold welds wouldn't work here.
Closed Thread
Cracks on JD 'E' block with JB weld Gilbert_Bates Antique Gas Engine Discussion 5 09-28-2007 10:43 PM
Cracks on JD 'E' block with JB weld Gilbert_Bates Antique Gas Engine Discussion 1 09-25-2007 09:21 PM
Welding Cylinder Head Josh Welding Shop 12 12-07-2002 12:22 PM
Repairing cracks in tires D.J. Baisch Antique Engine Archives 2 09-24-2002 12:17 PM
freeze cracks Tim Ray Antique Engine Archives 6 06-23-2002 07:46 PM
