Massey Ferguson Continental Z129
this thread has 5 replies and has been viewed 3069 times
Old 03-30-2011, 07:24:47 PM
Gusser Gusser is offline
Default Massey Ferguson Continental Z129
Im helping a couple friends put together a Z129 basket case they picked up. Im having a little trouble with the mains. first of all , the new crank is not machined to accept shims to set the thrust and I cant seem to get flanged main bearings . also the block does not have the line up pins on the inside of front bearing web to hold the brass thrust washer so it floats on the crank and is quite loose. just does not seem right . anybody run into this ?
Old 03-30-2011, 08:54:06 PM
Molinegb Molinegb is offline
Default Re: Z129
What is a Z129?
Old 03-30-2011, 10:30:45 PM
Default Re: Z129
continental 4cyl in a T030
Old 04-22-2011, 02:12:29 PM
Default Re: Massey Furgeson Continental Z129
Hmm, I have a manual I think at home, but I can't be much help if you already know the methods. You call Gerry Moons and ask him about it yet? There has to be an option; I know my E201 had the flanged center bearings, and I got them from Sealed Power.
Monte's Equipment
800-228-2625
www.montesequipment.com
montes@flash.net
Old 04-22-2011, 10:34:52 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
It sounds like you have parts for two different vintage motors mixed together. I believe the mains with the separate thrust washers are from the earlier style ,if you don't have the original crankshaft they are probably not compatiable with the newer style. F.J.W.
Old 04-25-2011, 10:58:40 AM
Default Re: Massey Ferguson Continental Z129
Interesting, I wasn't aware they would have changed this. If that's the case, you need to figure out which is correct, crank or block. Then the expensive part is next: Finding out which to buy....
Massey Ferguson TEF 513 567 louis viviers Antique Farm Tractors 0 06-06-2010 06:42:21 AM
Massey Ferguson 35, video Mozart.1756 YouTube Old Iron Videos 1 06-21-2009 12:20:04 PM
Massey Ferguson MHF TO 35 stolen! Mike in CA Antique Farm Tractors 25 04-24-2009 08:02:55 AM
Massey Ferguson 65 Rhys Antique Farm Tractors 0 08-25-2008 04:06:12 PM
Massey ferguson 65 Info? seharm Antique Farm Tractors 0 07-05-2008 04:23:47 PM
