Welding Shop
NAPA part# for SA-200 Zenith carb rebuild kit?
this thread has 5 replies and has been viewed 11212 times
Old 03-31-2011, 10:25:49 PM
ichudov ichudov is offline
Default NAPA part# for SA-200 Zenith carb rebuild kit?
I have a Lincoln SA-200 welder, powered by a gasoline F-163 continental motor.
The carb on it looks like a Zenith.
Would anyone know a part number for a rebuild kit?
---------- Post added at 09:25 PM ---------- Previous post was at 09:23 PM ----------
I would really love to get a NAPA part number.
Old 04-01-2011, 12:49:57 AM
ehpower2 ehpower2 is offline
Default Re: NAPA part# for SA-200 Zenith carb rebuild kit?
well unfortuanly napa came out with some new catalogs so i dont have correct part numbers but if you call them up i am sure you can numbers form them
Old 04-01-2011, 08:29:46 AM
Do you have old part numbers? I do not have the Zenith part number on the carb.
Old 04-01-2011, 02:50:41 PM
Dempster Dempster is offline
You could have a old style Zenith or later newer style the kits are NOT the same. Need to identify the carb you have on it. Keep looking if later style Zenith all aluminum there should be a number stamped on the top throttle body in a small circle. If it only had a tag and the riveted tag is gone there may not be a number. I could give you kit numbers but they wouldn't help if don't know which carb you have.
---------- Post added at 01:50 PM ---------- Previous post was at 01:38 PM ----------
http://www.asecc.com/data/continenta...arburetor.html
http://www.billswelderrepair.com/Engine-Drives.html
There are 3 or 4 different kits could be used unless you find a universal type kit. Zenith K7505 kits fits many transfers to BWD 12054. Or could be Zenith K2112 kit, or napa CRB21565 or 2-1565 or BWD 12066. These only fit the later Zenith not the earlier ones.
Old 04-05-2011, 08:48:18 PM
mmcdonald mmcdonald is offline
Banner Sponsor
Just to clarify the K7505 kit Dempster mentioned is for a Marvel Schebler TSX (cast iron top and bottom)which in most cases was original equipment. The K2112 fits a 68 Zenith pot metal top and bottom. It fits carbs that are widely used to replace the original. Earlier Zenith carbs used to replace the "MS" you can use Zenith K2068. The NAPA CRB21565 (that Dempster mentioned) should fit all the Zeniths that could be used within reason(it should have all the bowl gasket varieties).
info@mcdonaldcarb.com
The Following User Says Thank You to mmcdonald For This Post:
Old 04-07-2011, 05:21:28 PM
List of the Zenith and Marvel Schebler carbs for Lincoln Electric with their applications. OEM kit numbers listed along with Zenith replacement carb numbers.
Need help identifying a Zenith carb daddyfrank Small Air Cooled Gasoline Engines 1 12-04-2011 11:00:23 PM
Zenith Carb ID? jmsolomonson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 10-18-2010 02:50:34 PM
REO with Zenith carb GaryH Small Air Cooled Gasoline Engines 3 05-25-2009 11:43:09 AM
Zenith Carb Help bryna Antique Gas Engine Discussion 0 02-08-2008 07:21:22 PM
zenith cv 14 carb. Jim Wickham Antique Engine Archives 1 10-23-2003 08:58:17 PM
