| Machine Shop and Tool Talk Shop Equipment, fabrication, repairs, how to fix it, which tool to use for the job. Machinist shop talk, straight to the point. |
Enco Mill/Drillhi gang, i purchased an old, i guess 70's version enco m/d setup. not long ago, i discovered the...this thread has 10 replies and has been viewed 1599 times
hi gang,
i purchased an old, i guess 70's version enco m/d setup. not long ago, i discovered the coil spring on the side, for the spindle return is broken. i took a chance and blew 40.00 to find out a replacement is no longer available for this machine. they only carry the type for the newer machines. i'm looking to find someone who might be familiar with this and make a suggestion. thank you
Is that a flat wound, clock type, spring? Assuming it's broken near the end you could maybe shorten it an inch and re-do the end on your broken one. Might need to heat, bend & grind a new notch or something. Might limit travel a bit at the very end of stroke but might never be a problem.
The Following User Says Thank You to John Dunn:
I doubt it would limit the travel much at all if it were shortened a little bit, IF it works the same as the one on my old Buffalo drill press which is adjustable for tension and takes several turns of the knob to make much difference on the the tension.
Even if it's broken in the middle, it might be possible to tack weld it back together or silver solder it like a band saw blade splice as long as you use some kind of heat sink material to keep from weakening the spring beyond the break. If I'm reading the original post right, and he got the whole unit for $40.00 he got a great deal even with the broken spring. |
The Following User Says Thank You to OTTO-Sawyer:
If it is the clockspring type, another possible source is from rewind starters on small motors.they vary from little chainsaw types to quite heavy engine units. May need to modify as suggested above, but worth a try, Regards, Combustor.
The Following User Says Thank You to Combustor:
Have been known to make that kind of spring on the lathe using the spring steel banding from shipping crates. You have to cut your fingers all to pieces and take a couple raps up side the head before your done but it will work
The Following User Says Thank You to John C Walker:
i purchased a new one from enco (not same co. anymore). spring and housing cap $40.00. the rep. from enco warned me that they could only give me one from their newer machines and said it's not returnable. i figured, how much could they have changed and why not try it? and yup, ng. oh well, my mistake. by the way, ng on ebay. i'll check out shortening the spring. thanks guys
While you're checking out eBay for the 'old style' replacement, you could always list your 'new style' one on there.
Should be able to get at least some of your money back out of it, or if a couple people are looking for one and don't realise you can buy them new you could even turn a profit on it. If it was "Non Returnable", and you can't use it, you have nothing to gain by keeping it, and nothing to lose by selling it. You have the choice of starting low with the regular auction style listing & letting it go for whatever it brings, or putting it on as a "Buy it Now" listing at the $40.00 you paid or whatever price you will let it go for. Let us know how it all works out for you, fixing & selling... Just another suggestion.... you might try checking the Yellow Pages or online, and see if there are any spring manufacturers that could make either you a new one using your old one as a pattern, or might possibly have something in stock that would work for you. Maybe check the local machine shops and ask if they have any catalogs or business cards for spring suppliers. |
My 1984 vintage ENCO Mill/Drill has the clock work spring PLUS a standard extension spring connected vertically behind the drill quill column.
Kent |
The Following User Says Thank You to K D Redd:
well, i mickey moused the spring to get it back in and it seems ok but can anybody tell me if it has to be preloaded?
the manuals says nothing on this and not sure if i should wind it clock or counter clock wise. this is probably how it was broken in the first place. thank you |
It will need to be tensioned one way or another.
I've never looked at an Enco to see how they're put together or how they're adjusted. The only comparison I can make at the moment is on my old Buffalo drill press which has a hand wheel/knob that you turn for more or less tension, and it is adjusted after it's assembled. Turning the knob the opposite dirrection of the quill handle increases the tension, turning the same dirrection lightens it. As to where to set it, that kind of depends on how you're using it and what you have in the chuck. |
| Need advice on drill/mill | Elden DuRand | Machine Shop and Tool Talk | 22 | 09-18-2011 04:39 PM |
| 25 year old Enco mill/drill | 0002tense | Machine Shop and Tool Talk | 12 | 11-10-2010 05:26 PM |
| Enco Knee Mill Model No.? | Jim Richert | Machine Shop and Tool Talk | 1 | 03-20-2010 01:43 AM |
| Enco Mill - Drill Machine | Mike Grivna | Machine Shop and Tool Talk | 4 | 04-24-2009 08:35 AM |
| 3-IN-1 Mill/Drill/Lather??? | Rod Gordner | Antique Engine Archives | 21 | 01-31-2003 03:15 PM |
