Foam air cleaner generic replacement?
this thread has 10 replies and has been viewed 2850 times
Old 04-04-2011, 02:42:36 PM
Randy.ab9go Randy.ab9go is offline
Exclamation Foam air cleaner generic replacement?
What material should be used to replace a foam rubber air filter on a small 5 hp or less engine? The correct filter is no longer available (was a foam unit) so I will need to make one from scratch. Something I can source locally would be ideal.
Thanks,
Randy AB9GO
Old 04-04-2011, 06:18:04 PM
Default Re: Foam air cleaner generic replacement?
Would NAPA or a lawn & garden store not carry a suitable replacement element? What engine air filter are you looking for?
Bill
Old 04-04-2011, 08:58:12 PM
Suzuki SE1200 aka Toro T1200 (62012) generator. Parts listed as NLA except for the voltage regulator @ $400.00!! Toro Commercial 50-2470
DISCONTINUED. The unit was made from 1983 thru 1988.
Old 04-04-2011, 09:59:48 PM
Briggs Man's Avatar
Briggs Man Briggs Man is offline
You might try E-Bay, I have found numerous NOS items for small engines.. You might get lucky..
"The beauty of the 2nd Amendment is that it will not be needed until they try to take it away" -T.J.
Old 04-04-2011, 11:02:35 PM
Ironsides Ironsides is offline
In Australia we have a store called Clark Rubber and they normally carry bulk supplies,if they aren't too busy they will normally shape it for you.You must have something similar over there,Norm
Old 04-05-2011, 08:55:35 PM
David K David K is offline
Post a picture of the filter next to a ruler. I may be able to help.
Dave
Old 04-05-2011, 09:56:14 PM
manioso manioso is offline
You can eyeball how coarse or fine the foam structure is, and it must be "open cell" to work properly. You might be able to get sheet foam from McMaster-Carr and then cut it to shape.
Old 04-28-2011, 12:54:51 AM
Beanscoot Beanscoot is offline
I've tried to find this material. I checked at local Foam stores with no luck, but then found small sheets at work from unknown sources. To check if it is suitable open cell, just blow through it to see how restrictive it is. Compare it to a new B&S foam filter for cell size and ease of blow through.
Obviously Briggs and others buy this stuff by the yard and stamp out their filters. It is probably pretty cheap if you can find it.
Old 04-28-2011, 07:56:33 AM
Dick DeBuse Dick DeBuse is offline
One type of concrete expansion joint material is an open cell foam. It typically comes in 50' rolls of varying thickness and width. 1/2" thickness and 4" to 6" width is common. Construction supply houses carry this, as well as some home centers, such as Menards. You can probably add layers to make the correct thickness. One roll would give you a lifetime supply. You may be able to buy it in smaller rolls.
Old 04-28-2011, 10:15:29 AM
td5771 td5771 is offline
I don't know if grainger will sell to just anyone if you order online. I know you need a business and account to walk in of the street and buy something. buying online might be different.
but they do have the foam for filters, see link.
http://www.grainger.com/Grainger/Foa...CN2?Pid=search
Old 04-28-2011, 11:38:49 AM
Exclamation Re: Foam air cleaner generic replacement?
Grainger usually needs a corporate tax number to process sales. try a good motorcycle shop - they usually have aftermarket filters that you can cut to size. You might try an air filter element of an older B&S engine, and cut it to fit your filter housing.
Generic foam air filter material. Randy.ab9go Generators & Motors General Discussion 10 04-08-2011 10:01:39 AM
Clean or use Sea foam Twin34 Generators & Motors General Discussion 4 12-05-2009 05:35:08 PM
Foam instead of glycol in tires? Ric Richardson Antique Farm Tractors 6 11-03-2009 11:16:07 PM
Generic power washer Horse Power at 511 Garden Tractors / Mowers / Scooters 9 12-02-2008 01:28:49 PM
Wisconsin THD/TJD generic question Steve Dawkins Wisconsin Engines 4 02-06-2007 12:39:05 AM
