Onan 4CCK Oil Weight
this thread has 5 replies and has been viewed 1971 times
Old 04-13-2011, 09:16:27 PM
c east c east is offline
Default Onan 4CCK Oil Weight
Can't find proper weight for my gen set...Google says 40w for 30 to 100 degrees and 60 w for 100+.......40 w is hard enough to find...Where to get 60W?...Does this seem correct
4 .0 cck -3cr 4-12016r
sn.1274902779
Charlie
Old 04-13-2011, 09:49:46 PM
bobbyz72 bobbyz72 is offline
Default Re: 4cck OIL weight
you need 30wt for 30-100 degrees outside temp.... for those other weights just use rear end gear oil...lol
Old 04-14-2011, 08:28:38 AM
K D Redd K D Redd is offline
Default Re: Onan 4CCK Oil Weight
Engines DO NOT like the EP additive that is in gear oil. DO NOT put gear oil in a engine. If you want the higher weight oil you need to look to racing oil. That said good old Heavy Duty 30 will be all you need unless the generator is outside in zero degree weather. Then you might think about using a 10W-30.
Kent
Old 04-14-2011, 06:09:24 PM
Patrick Patrick is offline
Not to mention that gear oil is rated totaly ifferently than engine oil - a 75/90 gear oil is NOT the same as a 75/90 engine oil would be!
Old 04-14-2011, 08:31:44 PM
Ben Cowan Ben Cowan is online now
Smile Re: Onan 4CCK Oil Weight
I acquired my 4.0 cck in June of 2008. I use Castrol 30 wt. I am located in deep south Texas and winter temperatures are mild. I believe 30 wt is the best for mild to very warm summer temperatures and would be the original recommended oil for these units. Others seem to use the multi-viscosity oils. I have had no problems with the straight 30 wt oils for this unit. LOL Ben
Old 04-14-2011, 09:37:59 PM
David K David K is offline
Your right. Most people don't know that they are two totally different rating systems. 90 weight gear oil has about the same viscosity as a 40 - 50 weight engine oil. Not to mention the additive package is totally differnet.
2 cycle Detroit Diesels use 40wt oil. Any truck stop will have it. NAPA has it and so does Tractor Supply Co.
Some Harley-Davidsons use 60 wt engine oil. Any Harley dealer or motorcycle shop that deals with Harley-Davidsons (and their clones) will have 60 wt. They will have 50wt. too.
Dave
The Following User Says Thank You to David K For This Post:
Onan 4CCK for Christmas J.B. Castagnos Onan Generators 3 12-26-2010 09:49:38 PM
Should I buy? Onan 4CCK-3RV/1J - $120 yquem Onan Generators 6 09-28-2010 07:05:09 AM
Need manual for Onan 4CCK Diesel tech Onan Generators 13 08-03-2010 04:45:26 PM
Onan 4CCK help BGreen Onan Generators 1 01-23-2008 11:58:59 PM
Onan 4cck starter htcrkjak Onan Generators 13 09-17-2007 06:28:32 PM
