Where to buy large diameter V belt pulleys?
this thread has 13 replies and has been viewed 23285 times
Old 04-20-2011, 06:22:41 PM
Bigjoedo Bigjoedo is offline
Images: 21
Default Where to buy large diameter V belt pulleys?
Hello,
Looking for large V belt pulley (15-16 inch)to attach a small corn grinder to engine. Searched the net and ebay any ideas? Thanks
Bigjoedo
Old 04-20-2011, 06:32:31 PM
GlenK GlenK is offline
Default Re: Where to buy large diameter V belt pulleys?
Do you have any oldtime hardware stores in your area . You know the real hardware stores . They had alot of sizes hanging on the walls . Don't you miss the real hardware stores ?
The Following User Says Thank You to GlenK For This Post:
Old 04-20-2011, 06:32:35 PM
B.C. Cushing B.C. Cushing is offline
I'd try WW Grainger, McMaster-Carr, or stop at your regional electric motor repair facility, might be pricey. Could also put in an ad in this venue. We use to use these large pulley's, most were for large shafts and had several belts to go on the same pulley. You'll probably have to bush it down as larger belt sizes are for higher HP transmission.
The Following User Says Thank You to B.C. Cushing For This Post:
Old 04-20-2011, 07:05:13 PM
John Newman, Jr.'s Avatar
I should be getting a 'kick-back' for all the times I post a link to these guys!
www.surpluscenter.com
Cast iron. New. Sizes up to 18". 15" fixed bore: $40 for single groove, $62 for double groove . Choice of bore diameters.
Here are links to the pages with pulleys (PDF)
Fixed bore
http://www.surpluscenter.com/pages/Catalog284-122.pdf
H Bushed
http://www.surpluscenter.com/pages/Catalog284-123.pdf
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
The Following 2 Users Say Thank You to John Newman, Jr. For This Post:
Old 04-20-2011, 08:11:20 PM
TBellar TBellar is offline
I have some old sheet metal pullies ~14 and 20 inches in diameter that were used to drive the reel on a combine. They use a wide belt. The 20 incher has a 1+ inch ID bolt on hub the other has no hub. You can have them if you want them. I plan to attend the Portland swap meet. If you are interested let me know and I will get some accurate measurements for you.
Tom
The Following User Says Thank You to TBellar For This Post:
Old 04-20-2011, 08:28:11 PM
Zira Zira is offline
If you can find some one who services commercial HVAC units, they might be able to snag you one off a discarded blower. I see them at the scrap yard fairly often on the medium-sized units 9bigger than a house but not a lot). Good luck.
The Following User Says Thank You to Zira For This Post:
Old 04-20-2011, 08:35:06 PM
GarysToys GarysToys is offline
I don't know the shaft size you need but try an appliance store. The pulleys on old cloth dryers are fairly large and easy to remove.
The Following User Says Thank You to GarysToys For This Post:
Old 04-20-2011, 09:00:15 PM
BobM BobM is offline
well this may not help but i used those kids BMX cast aluminum wheels the kind with only 5 or 6 spokes
The Following User Says Thank You to BobM For This Post:
Old 04-21-2011, 12:52:45 PM
Images: 21
To clarify, looking for Pulley size 15-16 inches and Bore size 3/4". Thanks
Bigjoedo
Old 04-21-2011, 01:01:15 PM
m_thompson m_thompson is offline
Crap. I just paid about $9.00 each for motor run capacitors that they have for $1.99.
The Following User Says Thank You to m_thompson For This Post:
Old 04-21-2011, 01:24:38 PM
Bigjoedo
#1-BKH160 15.75" OD "H" Bushing single groove pulley $41.00
#1-2BKH160 15.75" OD "H" Bushing double groove pulley $64.00
#1-2913-75 3/4" bore "H" Bushing hub $5.00
John Newman, Jr.
Saint Louis, MO
Old 04-21-2011, 04:05:23 PM
Bob Willman Bob Willman is offline
I have a 19" - single groove with 1 1/8 bore not being used for anything.
The Following User Says Thank You to Bob Willman For This Post:
Old 04-21-2011, 10:41:59 PM
ar2stp48 ar2stp48 is offline
Thought I had one, but best I can find is 13 3/4" dia, 1" bore, possibly for B section belt as max width is 9/16".
The Following User Says Thank You to ar2stp48 For This Post:
Old 04-21-2011, 10:56:42 PM
Weldapulleys should be available at most farm equipment stores.
Buy a pulley, a weld-on hub and you're good to go (weld with a lkow hydrogen rod such as 7018).
http://www.ggmfg.com/products.aspx?c...y=Weldapulleys
While they are rated as only fractional horsepower they will stand a lot more than you think.......
I just reread the first post.......those pulleys wouldn't handle a grinder.....a sheller yes......but not a grinder......
Making Flat Belt Pulleys and their Crown Max Cox Antique Gas Engine Discussion 5 07-07-2010 08:23:24 PM
PTO Belt Pulleys Rex Piekarczyk Antique Farm Tractors 1 10-15-2008 09:56:27 PM
Help with flat belt pulleys CJ Winslow Antique Gas Engine Discussion 2 02-14-2005 02:01:57 PM
Re: Belt Pulleys-Don't just sit there, Do somethin Randy Antique Engine Archives 4 01-06-2000 05:35:21 PM
Belt Pulleys-Don't just sit there, Do something! Allen Antique Engine Archives 4 01-06-2000 12:59:05 AM
