Onan Coil Testing
this thread has 6 replies and has been viewed 7631 times
Old 04-22-2011, 12:12:38 PM
jcnfla jcnfla is offline
Default Onan Coil Testing
whats the procedure for bench testing a 166-0761 coil, ohm specs etc?? also what model harley davidson coil will replace it?? thanks, jack
Old 04-22-2011, 01:12:07 PM
markviiisvt4 markviiisvt4 is offline
Default Re: Coil testing
I don't have the answeres to your question, but as a side note I've been doing a little testing with GM wasted spark coil packs. This looks like it could turn out to be a viable option as they are very easy to come buy and cheep. Write up to fallow.
The Following User Says Thank You to markviiisvt4 For This Post:
Old 04-22-2011, 01:15:19 PM
thats an interesting concept, keep me informed...thanks
Old 04-22-2011, 10:05:43 PM
mrmegoo mrmegoo is offline
Default Re: Onan Coil Testing
In the service manual that you downloaded from the link by Max, look in section 6, page 6-12. This is very easy to follow for testing the coil.
Mel
Old 04-23-2011, 11:33:23 AM
K D Redd K D Redd is offline
The GM waste spark coil packs have a very low primary resistance. The one I have measured about .3 ohms. This will be pretty hard on a set of points. You might want to try using TWO ignition resisters. I DO NOT know if this will work. I have a 4.0 CCK that I am going to try to do a electronic ignition system on using two dowel pins in the flywheel, a proximity detector, a 4 pin GM HEI module, and one of the GM waste fire coils BUT I have not gotten the important aroundtoit part.
Kent
Old 04-23-2011, 01:20:56 PM
thanks to all that responded, it turns out the coil isnt the problem, its the ignition module rotor thats broken off inside. everythings a project...again thanks to all...jack
Old 04-23-2011, 10:36:41 PM
That's exactly where I'm at right now. I get about 150 straight hours on a set of points before they are BBQd. I want to try one off of a saturn 1.9 but they are a bit smaller and ill need to mod my rig a bit.
Coil testing Sky Small Air Cooled Gasoline Engines 6 02-16-2009 09:55:40 PM
Testing a spark coil? diggerdave Magnetos, Ignition Coils and Spark Plugs 2 06-15-2008 10:42:12 PM
Testing Maytag coil Robert Smales Maytag Engine Collectibles 2 11-16-2004 11:25:51 AM
Re: testing coil and condensor Russ Hughes Antique Engine Archives 0 07-22-2000 03:34:17 AM
testing coil and condensor Wesley Hay Antique Engine Archives 0 07-21-2000 09:06:57 PM
