Garden Tractors / Mowers / Scooters Vintage lawn and garden tractors, mowers, snowmobiles and other old machinery that is driven by small air cooled engines.
Cub Cadet 1864 Starter Problem
this thread has 9 replies and has been viewed 4684 times
Old 04-22-2011, 08:18:20 PM
Rex Piekarczyk's Avatar
Rex Piekarczyk Rex Piekarczyk is offline
Images: 8
Question Cub Cadet 1864 Starter Problem
1997 Cub Cadet 1864
Kohler CH18S
Spec. No. 62509
S/N 2413302087
565 Hours
Last summer the starter solenoid would intermittently engage, but nor far enough to close the contact to send power to the starter motor. Other times it worked just fine.
I disassembled, cleaned, lubed, and tested the solenoid/starter assembly. All tests passed, found that it would work as expected every time when not mounted to the engine. Solenoid drives the gear out, starter motor spins every time. The gears on the starter and engine don’t look damaged. Could this be an alignment problem between the engine and starter? There is a bit of movement available. Battery is new and fully charged.
Old 04-23-2011, 08:16:48 AM
Default Re: Cub Cadet 1864 Starter Problem
I'd say to check all wiring to the starter,and the ground's on the motor and chassis.I've had bad spot's in wires under the insulation before also.The wire's look ok but look for or feel the wires for bumpy spot's or area's where they may have been hot or corroded under the insulation.Mabe the switch is getting bad?? Try jumping past the switch and see what happen's.
The Following User Says Thank You to grub54891 For This Post:
Old 04-23-2011, 11:04:09 AM
Exclamation Re: Cub Cadet 1864 Starter Problem
When you test the starter, is it supported as it is mounted on the engine, or is it just laying on the bench? The selenoid coils may be weak. I have had them work fine on the bench, and when mounted, cannot work reliably against gravity, when mounted. As mentioned above, check your grounds. Make sure that the engine is grounded properly, and that the starter mounrs are clean and shiny, where it mounts to the engine Have you checked the motor armature for wear? If the commutater is worn, the mica segment seperaters may be obstructing full contact with the brushes. Just a thought.
Old 04-23-2011, 09:40:12 PM
Ken Karrow Ken Karrow is offline
Years ago I had a Cub Cadet with the 20hp Kohler, I believe it was a 2072. It was about a 1988 model (I bought it used). I had the same problem in about 2001 and had about 500-600 hours on it. Did all the things you describe. Dealer suggested a new starter. Said Kohler had improved the design in about 1999 or 2000 and his shop would not do anything with a unit with the old style starter except replace it if the tractor had more than 250 hours. I don't know if there was a lot of truth to this or if he was just selling complete starters but the new one was different than the old one and worked good. As I recall it was about $125 then and that unit was such a pain to pull the starter it seemed worth it. That was an opposed 2 cylinder and as I recall you had to remove the shrouds on the right head, bend slightly another shroud, jack up the right side of the engine, engine mounts are h**l to remove and your hands looked like hamburger when you were done. You might check with a good Cub or Kohler dealer to see if your starter has been superseded with an impoved version. That tractor taught me that I wanted power steering on my regular mowing tractor and that i didn't want any more opposed twins.
The Following User Says Thank You to Ken Karrow For This Post:
Old 04-24-2011, 03:15:20 AM
Images: 8
I just put in 2 new ignition modules, so the engine was removed, cleaned, and all ground connections and mounting surfaces are clean and solid.
I think the starter motor itself is good, since the failure occurs only when power isn't applied to the motor. If the solenoid does manage to throw the pinion gear out far enough to allow the motor contact to close it spins just fine.
I'll look into a new solenoid Monday.
Old 04-24-2011, 01:26:27 PM
Fred Van Hook's Avatar
Images: 480
Rex, I also own a 1864 Cub Cadet and had the same problem as you. I tried several things as you did but found my problem was the molded cable ends. I cut off the factory ends and bought the old clamp on ends. I am eventually going to replace them with some heavy duty stak-ons and use the marine type battery terminals,the ones with a bolt.
And how is the Fairbanks coming along??? I don't want to steal your thread but inquiring minds want too know!!!
A Atheist will never be able to say, "I told you so!!"
Engine movies can be seen at: pileofiron
The Following User Says Thank You to Fred Van Hook For This Post:
Old 04-27-2011, 09:14:09 AM
Images: 8
You have my deepest sympathy for being a 1864 owner. I'll send you pictures of the improvements I've made in an effort to make it actually useable. I already have the clamp on cable ends which aren't ideal, but do work. Send me a picture of the marine type terminals you mentioned.
The 1864 is a short timer here, I'm doing research on a replacement for it.
The Fairbanks hasn't changed since you saw it at Rainesville. It will be resting quietly in the garage until an new cart is made, which won't be any time soon.
Hope to see you at a show or two this summer.
Old 05-03-2011, 03:43:16 PM
Images: 480
Photo Re: Cub Cadet 1864 Starter Problem
Rex, Here is a picture of the cable ends I used on my truck. The gold color grease is Copper Sheild by Thomas & Betts. It helps a little on the connection but I use it more for a sealer to help keep the air out of the connection as it helps slow oxidation. Some guys I know use Never Seize on their terminals.
Old 01-01-2012, 10:22:01 PM
oldpiddler oldpiddler is offline
I had a little starting problem with my 1864 but a new battery solved it, I wish you could be that lucky.
---------- Post added at 09:22 PM ---------- Previous post was at 09:07 PM ----------
I had a little starting problem with my 1864 but a new battery solved it.
Old 01-02-2012, 12:17:54 AM
Tom Marshall Jr.'s Avatar
Tom Marshall Jr. Tom Marshall Jr. is offline
Images: 1
Mine was a clicker, several times and it starts.I put a small GM relay at the starter. key switch works the relay and it works the starter . I got tired of using a screwdriver to start it. From the key switch threw the blade clutch switch on to the clutch pedal switch, a large plug connector then the start wire goes to the starter. voltage drops as you go from one end to the other. The relay solved the problem. Tom
Cub Cadet 1864 CV Joint Assembly Rex Piekarczyk Garden Tractors / Mowers / Scooters 2 04-22-2011 02:39:12 PM
John Deere 620 Starter Problem patrickingalls Antique Farm Tractors 3 02-19-2011 04:14:03 PM
1864 Cub Cadet concern BDMelon Garden Tractors / Mowers / Scooters 8 11-09-2010 07:28:55 PM
Cub Cadet 104 Ignition Problem pumpkin farmer Garden Tractors / Mowers / Scooters 4 07-31-2010 12:24:04 PM
CUB CADET model 1864 problem Flying mower guy Garden Tractors / Mowers / Scooters 5 09-25-2009 04:49:51 PM
