Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engine Collectibles
Maytag Points
I'm in desperate need of the professional knowledge that comes from this forum. I'm in the process...
this thread has 2 replies and has been viewed 1150 times
Old 04-25-2011, 01:05 PM
allgattill allgattill is offline
Default Maytag Points
I'm in desperate need of the professional knowledge that comes from this forum. I'm in the process of restoring a model 92. My flywheel was cracked where it fits around the crank so I purchased one off ebay. Today, I started the process of transferring everything over to the newer one. When I attempted to remove the points, several of them slipped out from underneath the screws (both sets of points). Now I'm not sure how they go back together or how many are required on each side. Oh by the way, I know, I should of used a jig but I was impatient. Come on guys, don't laugh, help a newbe out. Thanks in advance to all who respond.
Old 04-26-2011, 09:28 AM
Dennis Wyatt's Avatar
Dennis Wyatt Dennis Wyatt is offline
Images: 101
Default Re: Maytag Points
Here is a couple of pictures of some points on ebay right now. You should be able to see the lamination order in these. Good luck!
Dennis
http://www.youtube.com/user/djjr4fun#p/u
The Following User Says Thank You to Dennis Wyatt:
Old 04-29-2011, 07:56 PM
Mark Shulaw Mark Shulaw is offline
Heres an image thats a little brighter that might help. If the flywheel was broken not sure why you had to mess with the points in this fashion. Need your points properly positioned get it to me. I have the original factory points placement gage. Or catch me at a show if we get to the same ones. Maytag Mark
Maytag pinned points? cheddarhead Maytag Engine Collectibles 2 10-13-2010 08:29 PM
Maytag 92 points issue Malcolm M Maytag Engine Collectibles 5 08-09-2010 07:33 PM
maytag model 72 how do you clean the points? Canadian made Maytag Engine Collectibles 2 10-29-2009 05:18 PM
Maytag 92 points adjustments and timing? shiftlessguy Maytag Engine Collectibles 4 03-26-2008 01:59 PM
points for #72 don Generators & Motors General Discussion 1 05-02-2001 10:27 PM
