Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Antique Engine Photos
Antique Engine Photos OLD gas engines, hot air engines, Diesels and steam engines. An electronic photo gallery to showcase the best of your old engine collection.
Root & Vandervoort
Help: I need help & pictures of a 4hp Root & Vandervoort not sure what it takes to make the spark ?...
this thread has 6 replies and has been viewed 2397 times
Old 04-25-2011, 08:10 PM
bige186 bige186 is offline
Default Root & Vandervoort
Help:
I need help & pictures of a 4hp Root & Vandervoort not sure what it takes to make the spark ? Will post pictures of what I have. Also need the Gov.
Old 04-25-2011, 09:00 PM
Elden DuRand's Avatar
Images: 6
Default Re: Root & Vandervoort
Your engine looks to be modified somewhat.
I think it originally had an ignitor in place of the block with the spark plug. I don't know how the original system worked, if it had a mag, etc.
Good luck!
Take care - Elden
Take care - Elden
http://www.eldensengines.com
Old 04-25-2011, 10:57 PM
Images: 1
Photo Re: Root & Vandervoort
You are missing the ignitor and trip. Here is one on a 1hp:
R&V used the same ignitor on all the different horsepower 'Triumph Line' engines.
Here is the govenor in place on the 1hp engine:
and the almost finished govenor for my 4hp engine:
The govenors are the same design on the different horsepower L Line engines but are just scaled up.
There are more pics of my various R&Vs at:
http://www.oldengine.org/members/pml/rvindex.html
Patrick
The Austral Register
http://www.oldengine.org/members/pml/index.html
The Following User Says Thank You to Patrick M Livingstone:
Old 04-26-2011, 06:54 AM
WildIrishman52's Avatar
WildIrishman52 WildIrishman52 is offline
Images: 1
Your engine is a 1912. You are also missing the fuel line and the detent block which goes in the top hole above the pushrod. The detent block is used by the arm from the governor assembly to allow the engine to coast between firings. Mike Schlender in WI may be able to help you with parts. His contact info is listed on the R & V website.
Good luck, Joe
Old 04-26-2011, 01:26 PM
Gary Pflum's Avatar
Gary Pflum Gary Pflum is offline
These are some pictures from my 4 hp CL engine I just finished. I hope they will help. I also noticed that your tag is like mine and somewhat different. Notice that the HP on the tag is crowded together. Others that I have seen are just HP. My serial number is CL31398.
The Following User Says Thank You to Gary Pflum:
Old 04-26-2011, 09:52 PM
speleausmining's Avatar
speleausmining speleausmining is offline
Images: 232
As is it has been rigged to opperate a buzz coil somehow. Usually the ones I have seen are done by either adding a pin onto the cam gear to contact a wiper. Or by using the old ignitor trip to contact a wiper. Since your missing the igniter trip I would assume the former. I also saw a bizare setup were they used the ignitor to time the buzz coil. Seemed to me like that set up combined the worst of both worlds. You still had to time the ignitor to the engine and in an essentially dead space off of the cylinder it would be highly suseptable to fouling.
Old 04-27-2011, 02:54 AM
Images: 1
My CL has a long way to go
It has the more generic R&V tag with no mention of JD.
Root & Vandervoort Value Ironman Antique Gas Engine Discussion 2 01-20-2007 06:02 AM
need some Root & Vandervoort 2 Hp help Tom Sampson Antique Gas Engine Discussion 7 11-06-2006 05:21 PM
Root & VanDervoort Peter Lowe Antique Engine Archives 0 09-23-2001 05:36 PM
Root & Vandervoort Patrick M Livingstone Antique Engine Archives 0 01-23-2001 05:38 AM
root and vandervoort wipp Antique Engine Archives 0 08-17-1999 01:00 PM
