Onan stop solenoid 307-2546-00 used on DKD, MDKD and others
this thread has 7 replies and has been viewed 9718 times
Old 05-04-2011, 05:59:33 PM
kg5388 kg5388 is offline
Default Onan stop solenoid 307-2546-00 used on DKD, MDKD and others
There seems to be a lot of mystery on how to install and adjust the fuel shut down solenoid.
The pull and hold coils seem to create a problem
woodward
model 1502
part number 307-2546-00
12 vdc
lay it on the table and connect a meter to the pos and neg terminals and ohm them out
notice the low ohms of the pull coil
now pull in the plunger
see the high ohms of the holding coil
now notice if it is not ALL the way in the internal switch will not change from the pull to the holding coil
Now lets mount the solenoid
Last edited by BTPost; 06-21-2011 at 09:03:15 PM. Reason: Fixed voltage of solenoid....
Old 05-04-2011, 06:02:23 PM
Default Re: how to--stop solenoid 307-2546-00 used on DKD, MDKD and others
now lets move the linkage notice it is at the end of its travel but notice it does not travel all the way into the solenoid so the internal switch has not been activated
now we will adjust the linkage by turning out the connection point where the ball connects to the lever
see how the solenoid bottoms out and the internal switch changes from the pull to the holding coil
now check to make sure the lever will hit the stop when fully extended
make sure the wire connections are good and tight and start the genset.
The other thing I do that no one else does it see the 2 wires getting a ground from the mounting screws. I use so emory cloth or small grinder and remove the paint from the screw holes and face of the mounting bracket for a good connection.
The Following 4 Users Say Thank You to kg5388 For This Post:
Old 06-22-2013, 12:44:08 PM
admiralmutiny admiralmutiny is offline
Default Re: Onan stop solenoid 307-2546-00 used on DKD, MDKD and others
I ordered a new solenoid, but it does not have the AUX terminal. I installed as directed and now the generator starts when I push start and connect the wire that was on the AUX of the old solenoid to the "NEG" of the new solenoid. I tried holding it to the terminal and it sounded like the starter automatically kicked off. I checked the wiring diagrams and diagnostics in the manual and it appears that this wire can go to the hold coil (or "NEG" terminal) because the start solenoid kicks off via another circuit once the AC voltage goes up. Can anyone confirm this? Has anyone installed a 2-terminal instead of a 3 terminal solenoid? It was $150 cheaper, but advertised as a direct replacement. The part number of the original is the same as the subject thread, the new one was 1504-12A6 "replaces 307-2546". I'm gonna leave the wire disconnected and manually start it up until I hear back. Thanks!
Old 07-02-2013, 12:52:17 AM
nnyerges nnyerges is offline
Originally Posted by admiralmutiny View Post
....I checked the wiring diagrams and diagnostics in the manual and it appears that this wire can go to the hold coil (or "NEG" terminal) because the start solenoid kicks off via another circuit once the AC voltage goes up. Can anyone confirm this? Has anyone installed a 2-terminal instead of a 3 terminal solenoid? It was $150 cheaper, but advertised as a direct replacement. The part number of the original is the same as the subject thread, the new one was 1504-12A6 "replaces 307-2546". I'm gonna leave the wire disconnected and manually start it up until I hear back. Thanks!
For a 3 terminal solenoid, the (+) and (AUX) have a +12Vdc source controlled by your generator and the (GND) is the negative of the battery. You should buy a 3 terminal solenoid like the 1502-12d6u1b2s1a (i just buy one to my Onan generator), but you can still use the one with two terminals.
These solenoids have to coils inside: a high current pull coil and a low current retention coil. The two terminal types have a internal switch that control the power source for each coil. The 3 terminal types use the (AUX) terminal to power the retention coil (from a external switch).
Connect the ground (GND) terminal and the other two cables to the (+) terminal. I don’t think there is any problem with the current on the AUX cable, since today is very hard to find a 3 terminal solenoid. Most come with the internal switch.
I find my in “aerial equipment parts”, but i have two wait two weeks to get it.
Old 06-11-2015, 08:57:39 AM
sceason sceason is offline
I haven't posted in a while but I have a f/u solenoid question that hopefully will get some good feedback from some of you walking encyclopedia types.
I have a 2001 model yr. Onan 7.5 kw generator, model HDKAL-2C (commercial spec C) that I've owned for several years and use as backup power for my home. It runs great but with 1 exception; I have to give the fuel solenoid a push w/ my hand to get it to trip that internal switch and start. I guess these fuel solenoids have 2 or 3 wires? Mine has 3 wires if it matters. After warming up the glow plugs, I'll hit the start switch, and it sounds like the starter starts clicking (like it would with a dead battery), then the DC breaker will trip on the start panel if I don't pretty much immediately push that solenoid further in by hand. Once I push the solenoid further in, it starts flawlessly and runs fine.
My question is this: is the fuel solenoid's pull coil bad, or is it just improperly adjusted? I've never messed with it since I bought it with approx. 2000 hrs on it.
Any input would certainly be appreciated as these things aren't cheap!
Steve
Old 06-11-2015, 12:47:09 PM
BigBlockChev's Avatar
You just need to adjust the linkage to allow the plunger to bottom out . Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
The Following 2 Users Say Thank You to BigBlockChev For This Post:
Old 06-14-2015, 09:57:27 AM
I have the 7.5 KW diesel gen but the newer version - the HDKAL which has the Kubota Series 5 type D1105 engine. Can anyone confirm if my 3 terminal fuel solenoid should use an internal or external retention switch? The one on my used set is internal but I can't seem to get it adjusted so that it pulls in properly. Even after adjusting it I have to manually push it in to start it. Thereafter if runs fine. If I replace it, I want to ensure that my unit has the external switch. Others references seem to say they are all internal. Thanks y'all. Steve
Old 06-22-2015, 03:33:12 PM
I since read that the 7.5 HDKAL genset uses an internally switched solenoid. At least my service manual seems to indicate that - if I read it correctly. Can anyone 2nd that?
Onan MDKD 8.0kw voltage to high 145vac Pender Onan Generators 15 05-08-2011 10:44:31 PM
Onan 6.5kW MDKD Wiring Diagrams DNilsson Onan Generators 9 04-25-2011 10:14:30 AM
Onan 3DJA Stop Solenoid Burnt Out Gasman327 Onan Generators 17 11-15-2006 07:26:45 PM
Help! Can't start Onan 8k MDKD jeffgregory Onan Generators 10 09-17-2006 09:09:26 AM
Starting my MDKD Onan Geny John Chartrand Onan Generators 3 01-10-2004 05:55:19 PM
