Manual for Onan 4500 Generator
this thread has 20 replies and has been viewed 17890 times
Old 05-21-2011, 11:47:28 PM
wmpick wmpick is offline
Question Manual for Onan 4500 Generator
Hi, I'm new to the forum have already read and took in some valuable info-THANKS!
I just purchased 1997 Ford bucket truck with Generator and need to find the manuals for it to help me to service and understand better.
It is a 4.5BGDF-B30502M , ser# is K010301883 , I would like to find or better yet get it in PDF so I can store on computer. Do one of you experts have the Operator, Service,Parts manuals for this unit . also a wiring diagram could be helpful.I have got confused about these model #'s and the gen. code?? Thanks for any help you can give. Wm.
Old 05-22-2011, 01:57:07 AM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: Manual for Onan 4500 Generator
Yous is a 4.5kw BGD Stationary 120/240 Vac non-Reconnectable Genset, with an (M) Spec Code. Built in November of 2001.
Bruce in alaska
The Following User Says Thank You to BTPost For This Post:
Old 05-22-2011, 08:01:08 AM
Default Re: Manual for Onan 4500 Generator
Thanks for the basic info BT- Does anyone have any of the manuals they could send me- My email is wmpick@msn.com
Old 05-22-2011, 09:47:54 AM
http://www.cumminsonan.com/www/pdf/manuals/965-0129.pdf
Operators
http://www.cumminsonan.com/www/pdf/manuals/965-0135pdf
Operators
http://www.cumminsonan.com/www/pdf/manuals/965-0175.pdf
Operators
http://www.cumminsonan.com/www/pdf/manuals/965-0500.pdf
Service, begin spec. H
http://www.cumminsonan.com/www/pdf/manuals/965-0529.pdf
Service
I will send the parts manual to your e-mail. The above files may be slow to download, be patient.
The Following 3 Users Say Thank You to Max Thompson For This Post:
Old 05-23-2011, 09:29:19 AM
Thanks very much Max! now I got me some reading to do
Old 06-29-2011, 08:39:17 AM
mikey1701 mikey1701 is offline
Hello Max, I have found your link to be very helpful in my situation as well. My Onan Commercial 4500 4.5 BGDFB30502M came on a bucket truck bed I bought (Telsta A 28 D) to fix up and do electrical work. I bought it at a junk yard, unfortunately someone stole the control board, carb, fuel pump, VR1,VR2 and starter off the generator before I got. ( the theives knew how much this stuff is worth) I have another older Onan BGD 4.5 that I am robbing parts to fix the one on my truck. However I have found the wiring harness plugs are different. I am in the process of making an adaptor to use the 300-3763 board. I have no clue what board my generator had before I got it. The harness plugs are orange if that helps. I can't afford to sink a lot of money in a new board at this time and wanted to know if this is possible before I proceed. Please don't hold anything back as I am new to this type of gen and I am just winging it one wire at a time. Any and ALL advise would be appreciated. Thank and God bless you
Old 06-29-2011, 04:26:55 PM
You need the advice of the “Smart Guys”. Some units you can wire with out the control board, but I don’t think you can get around the VR1 & VR2, both of which are likely upwards of $100 at flight systems. Does your older BG run? Could you swap it out for the one in the truck? If you are not in a hurry, you can often find running 4.0 – 6.5 units in the $200 -$400 range, may be cheaper in the long run.
The Following User Says Thank You to Max Thompson For This Post:
Old 06-29-2011, 07:03:29 PM
I have the VR1 and VR2 installed, the VR1 has the capacitor and a 12 pin connector. If I had it to do over I would have swap them out. I have already installed and wired up everything except the wiring harnesses because they don't match. If you could give me the wiring diagram for my gen. s/n F990932139. The diagrams I downloaded are good but some of the numbers are unreadable. Thank you for all you help, God bless
---------- Post added at 07:03 PM ---------- Previous post was at 06:34 PM ----------
ps, I have the control board from my old BG, it had a different 12 pin connector than my newer BG.
Old 06-29-2011, 08:01:07 PM
If I am reading correctly, page 99 of manual #965-0500 should be the wiring diagram for your unit. The down load manual from Cummins is clear & easy to read if enlarged on screen. Hopefuly someone that "knows" will be along & help you out.
Old 06-29-2011, 08:30:02 PM
Thanks Max, that's it. I needed the print I could see the numbers and letters. I can wire it up with this, I just hope it works correctly and I don't miss something. I have to relocate some wires that went to the starter solenoid ( my old starter doesn't have a solenoid attached to it ) but I can work around this. I mounted the solenoid behind the control board like it was in my older BG. I'm not going to try it until I get more info, don't want to cause any damage. Thanks again Max and God bless
Old 06-29-2011, 09:38:21 PM
George Clark George Clark is offline
no problem send me an email at georgenfw@hotmail.com include your model number and i will send you the proper manuals and what ever info tou need.no wories mate
The Following User Says Thank You to George Clark For This Post:
Old 06-30-2011, 10:47:57 AM
Thanks, all help is appreciated.
Old 01-02-2015, 01:28:56 PM
purple purple is offline
I have 4500w bgd onan generator used in a bucket trust were can I get oil filter#s air filter#s.
Old 01-04-2015, 07:39:13 AM
bigjl71 bigjl71 is offline
Question Re: Manual for Onan 4500 Generator
Can anyone tell me in laymen's terms how to make an Onan 4.5 Genset become functional by the onboard start/stop switch, because the remote panel has been removed with the wires simply cut where they exit the start/stop panel? Thank you.
Old 01-04-2015, 10:02:17 AM
MBB MBB is offline
Welcome to the Stak. You will find plenty of help here but you need to be a little more specific. Model number, Serial number a picture would help. Just guessing if the wires were just cut from the remote it should be as easy as pushing the start button on the unit. The remote wires unless shorted out should not prevent control at the unit.
Old 01-04-2015, 12:53:07 PM
len k len k is offline
Typically.......... press start to start, ........stop to stop.
Remote switch usually just is in parallel with gen's switch
Tape the wires so they don't short.
Old 04-29-2015, 06:02:40 AM
Sean s Sean s is offline
The 965-0500 book is the one I need it won't open any idea it saying timed out
Old 04-29-2015, 07:02:22 AM
Billy J Shafer's Avatar
Post an email address and someone will send you one.
Old 11-17-2015, 04:36:06 AM
Dragon Randy Dragon Randy is offline
Lost my files need a copy of the manuals for the Onan 4500w BGDF Generator, also need the electrical diagram, having a problem with my Shore/Gen Auto Switch so if anyone has a diagram of the connections that be needed to,,,
Thanks ahead of time
Old 11-17-2015, 06:58:21 AM
Kevin K Kevin K is offline
You can download a pdf copy of the manuals here:
http://www.twinslan.net/~n0nas/manuals/onan/
If you need any further help, you need to post the COMPLETE model number.
The Following 3 Users Say Thank You to Kevin K For This Post:
Manual for a 705 CW onan generator Amy Foringer Onan Generators 5 01-22-2013 03:23:55 PM
Manual for Onan 6.0 DJE Generator memphisdoug Onan Generators 6 10-27-2012 05:53:17 PM
Onan 4500 Ignition Ring Part Number werowance Onan Generators 27 04-25-2011 04:04:43 PM
Onan 4500 out of Bucket Truck - question werowance Onan Generators 5 03-29-2011 05:56:28 AM
Manual for Milwaukee 4500 or 4520 generator? django Generators & Motors General Discussion 0 02-01-2009 03:44:10 PM
