Sleeper trailer-1
These photos may not look like much progress but they are the result of two good days worth of...
this thread has 1 replies and has been viewed 1473 times
Old 06-05-2011, 04:43 PM
jdcrawler jdcrawler is offline
Default Sleeper trailer-1
These photos may not look like much progress but they are the result of two good days worth of work.
The windows are all removed and I've started to remove the edge trim from the front.
There are a million screws holding these windows and trim on ( well. maybe it just SEEMS like that many ).
I figured that once the windows and edge trim are removed, the side panels would slip right off. .... WRONG !!
The side panels are first fastened on with tiny nails about every 6-inches.
Then the top and front panels are put on and about 3/4 inch of metal is bent over the side panels.
Then they nailed thru the bent over edge about every 6-inch.
So .. I had to get all the nails out of the bent over edge, then lift the edging up so I could pull all the nails out of the side panels.
Finally, I got the side panels off.
When I stood back to take a good look at it, my first thought was " what in the heck have I gotten myself into this time ?"
The wood is all rotted away from around the window on this side.
Some of the wood is rotted below the window on the other side also.
The wood on the overhang isn't in too bad a shape on this side.
The Following 2 Users Say Thank You to jdcrawler:
Old 06-05-2011, 04:45 PM
Default Re: Sleeper trailer-1
The very front corner area is rotted out so those pieces will have to be replaced but that shouldn't be too much trouble.
The wood on the overhang on the other side all looks good.
Ray
The Following 4 Users Say Thank You to jdcrawler:
Sleeper Trailer jdcrawler Trucks, Trailers and Hauling for Shows 4 06-03-2011 07:02 PM
Did I miss a sleeper? JHFoster Stationary Steam & Traction Engines 2 07-13-2008 11:31 PM
my 99 taurus sleeper car yamaha v8 CODY K Antique Autos and Trucks 12 06-24-2008 08:20 AM
To trailer or not to Trailer? That is the question Adam Cottrill Trucks, Trailers and Hauling for Shows 5 08-03-2003 05:23 PM
So now where do I go for a new trailer Steve Gerot Antique Engine Archives 11 03-31-2003 10:52 PM
