Briggs 4hp Power Reverse
And another recent find, http://www.flickr.com/photos/17087539@N07/, a Briggs 4hp Power Reverse...
this thread has 7 replies and has been viewed 1172 times
Old 06-19-2011, 02:10 PM
Nevr-Enuf-Stuf's Avatar
Nevr-Enuf-Stuf Nevr-Enuf-Stuf is offline
Photo Briggs 4hp Power Reverse
And another recent find, http://www.flickr.com/photos/17087539@N07/, a Briggs 4hp Power Reverse vert. shaft, model #100902, code #7006307, type #0320-01. Year? Application? it has a pulley and a "cup" that looks like it might have been part of a clutch at some time. What exactly does it mean by "Power Reverse"?
Patrick
You may have to roll down the page Ive added more pics of other "stuff".
Old 06-19-2011, 03:07 PM
Default Re: Briggs 4hp Power Reverse
Would guess the engine is from a rototiller.
Bill
The Following User Says Thank You to Bill Sherlock:
Old 06-20-2011, 12:26 AM
ken karrow ken karrow is offline
Agree with Bill, power reverse decal came from manufacturer of equipment. Reverse was possibly accomplished by running a belt on the pulley for forward and a roller riding the drum for reverse.
The Following User Says Thank You to ken karrow:
Old 06-20-2011, 08:30 PM
Thanks, I appreciate the input. I had forgot that the first two digits of the code # was the year of manufacture. This engine was a $4 find, Im sure I could find some use for it.
Patrick
Old 06-21-2011, 08:58 AM
brew56 brew56 is offline
I have the same engine on my tiller but it does not have that strange cup on the pulley.
Old 06-21-2011, 10:51 AM
David K David K is offline
A Simplicity front tine tiller I worked on last year had the same (or very similar) setup. The pulley drove a belt, the belt went around a couple idlers and did a 180 degree turn thus driving the tines in reverse. That's were the "reverse power" comes in.
The bottom cone part is one half of a cone clutch. The other half is probably still attached to the tiller the engine came off of. The cone clutch drove the tines forward. It was a neat design but a pain to work on.
The engine looks to be the older "big block" line of B&S 4 & 5 hp engines. As the name suggest, they were larger than other 4 - 5 hp engines. They were well made, probably lasted longer and probably had more torque then their smaller 4 - 5 "cousins". But they were heavier due to there larger size and thus not often used were light and cheap (example: lawnmower) was a requirement. They were, however, often used on high-end Snapper lawnmowers which were often self-propelled so the extra weight was not a problem. Plus the customer paying extra for the high-end lawnmower wanted it to last also.
I might have a parts manual for the Simplicity tiller if you are interested in it.
Dave
The Following User Says Thank You to David K:
Old 07-09-2012, 10:18 PM
ClassicTVMan1981 ClassicTVMan1981 is offline
This is from a 1970 Sears Roto-Spader model 785.290040.
The engine's code means a date of manufacture of June 30, 1970.
Some other Sears Roto-Spader models used the model 100992 type 0330-01 engine, also a B&S 4 HP "big block."
~Ben
The Following User Says Thank You to ClassicTVMan1981:
Old 02-18-2013, 05:56 PM
recentjester recentjester is offline
I have an old rotospader with a 4hp tecumseh on it vertical motor. I need a pic of the clutch linkage to the handle. I will have to make some kind of handle to engage the cone clutch. All that is there is a small spring hanging on the clutch lever.
---------- Post added at 06:56 PM ---------- Previous post was at 06:54 PM ----------
I could sure use it Dave. a pic of the clutch linkage and Handle, would help me immensely.
Briggs Power Chargers SBreeden Small Air Cooled Gasoline Engines 9 04-06-2009 09:10 PM
Another newbie find, briggs "A" with marine reverse gear mschreiber Small Air Cooled Gasoline Engines 17 09-28-2008 04:20 PM
WW II Power Unit,Briggs B OldironJeff Generators & Motors General Discussion 15 03-29-2008 05:47 PM
Briggs Kickstart pedal in reverse. James Wallace Small Air Cooled Gasoline Engines 3 02-06-2008 10:57 AM
Can you make a Briggs and Stratton go in reverse? dan000001 Small Air Cooled Gasoline Engines 2 05-13-2005 01:55 PM
