Welding Shop
welding a cracked piston
I managed to crack the face of the piston on my 1 1/2 H.P. McCormick M while removing it. My...
this thread has 1 replies and has been viewed 1187 times
Closed Thread
Old 05-19-2003, 01:28 PM
Tanner Remillard
Default welding a cracked piston
I managed to crack the face of the piston on my 1 1/2 H.P. McCormick M while removing it. My question is would it be save to "V" out the crack and weld it up, then grind it down smooth without the worry of something breaking later on? I dont see why it would'nt work but would the heat of welding effect the piston any?
Old 05-19-2003, 04:15 PM
Steve Cox
Default Re: welding a cracked piston
Tanner, I would recommend you get a different piston. There should be plenty of them available. The piston could come apart when running and would certainly cause damage to the bore or even more. My 3 cents (inflation) worth. Can probably find one in one of Harry's advertiser.
Closed Thread
Piston Spray Welding Tom Wahl Antique Gas Engine Discussion 8 11-29-2007 08:24 PM
Cracked Piston in MM/TC KTA Jeff Blaney Antique Tractor Talk 4 07-15-2007 01:04 AM
Piston Ring Material for Custom Machined Piston Rings. Uncle Old Iron Antique Gas Engine Discussion 3 06-24-2007 02:50 AM
spray welding piston oversizing Charlie Conner Welding Shop 3 10-10-2005 12:36 PM
Repair? Piston cracked on side Roger White Antique Engine Archives 1 07-18-2000 03:05 AM
