Need Help with Miller AEAD-200LE Onan Engine
this thread has 15 replies and has been viewed 7086 times
Old 07-18-2011, 10:13:28 AM
hotrog hotrog is offline
Default Need Help with Miller AEAD-200LE Onan Engine
I just inherited a Miller AEAD-200LE. But i cant get it to start. No spark at the plugs. The engine is a 2 cylinder Onan CCKA-MS/2748J. Condenser and points are ok. I got 2 new plugs. Welder was siting for about 10 years.. Can somone help???
Old 07-18-2011, 04:03:44 PM
Default Re: Need Help with Miller AEAD-200LE Onan Engine
I am not familiar with this unit, is it elec. start or recoil? If it is elec. start, do you have 12-V at the coil? Looks like it would be a spec. J.
http://www.cumminsonan.com/www/pdf/manuals/927-0754.pdf this link will get you a CCKA engine service manual. Give it some time to down load.
I have # 927-1060 CCK welder parts manual if it will help, I need an e-mail address to send it to.
The Following User Says Thank You to Max Thompson For This Post:
Old 07-18-2011, 06:53:49 PM
Douglas123 Douglas123 is offline
Smile Re: Need Help with Miller AEAD-200LE Onan Engine
If you can get the serial number off of the unit I still might be able to pull up the original owners manual for this unit.
The Following 2 Users Say Thank You to Douglas123 For This Post:
Old 07-18-2011, 07:29:29 PM
lokay5 lokay5 is offline
First, do what Max said; check for 12V at he coil positive.
It may be that after sitting for so long, the oil pump may not be able to pull oil to build pressure at cranking speed (unlikely) or the switch may be bad (possible)
Try bypassing the "Low Oil" switch by disconnecting it at the coil negative.
The Following User Says Thank You to lokay5 For This Post:
Old 07-19-2011, 09:20:50 AM
Thank you so mutch for the manual max.. It was verry helpfull.
That would be great if you could. Her's the # 8770 207864 . And again. It is a CCKA-MS/2748J
Old 07-19-2011, 05:34:54 PM
davidradio davidradio is offline
on miller welders on the control plate where all switches and plugs are
there should be a serial number there will be two letters than numbers
this will give year built of welder b is 1 there is no I
example bc would be 12 also check miller web site for more information
dave
The Following User Says Thank You to davidradio For This Post:
Old 07-19-2011, 06:58:15 PM
Where do you want me to send it? Post or PM me an address, if you send me a PM, jog my memory as to what you are needing.
Old 07-20-2011, 08:18:12 AM
Thank's Douglas. You can send it post if you like, Or via email. rog107@hotmail.com Thank's again..
Old 07-21-2011, 12:18:27 AM
give me a little time . Been out of town past few days, A quick note. I still have greenitis but had to modify a 41 year old EK with a 21st century contoller. The good note is I left all the original controls intact and inplace to include the original magniciter circuitry. Will post some pics when I get a moment.
The Following User Says Thank You to Douglas123 For This Post:
Old 07-21-2011, 05:22:31 AM
Sound's good Doug. Thank's again..
Old 07-22-2011, 12:35:02 AM
Kimbra Dean Kimbra Dean is offline
Have you checked the points with a meter. Sometimes points that have been setting a long time will get a thin layer of oxidation that will prevent them from making contact. This oxidation may not be readily noticable.
The Following User Says Thank You to Kimbra Dean For This Post:
Old 07-22-2011, 11:30:53 PM
Check your E-mail. Should be the correct owners manual. if not there are several others.
Old 08-21-2013, 08:29:01 AM
dw4tl05 dw4tl05 is offline
i have a miller aead 200 LE onan engine , when you start it , it blows oil out the dipstick & out and around the breather ? can anyone help please
Old 08-21-2013, 08:47:03 AM
Billy J Shafer's Avatar
Your breather valve may be stuck closed. I am working on the same welder at this time.
Old 08-21-2013, 08:51:26 AM
Daverepair Daverepair is offline
If you have a new question , start a new thread please. You will definitely get some help.
Billy jumped right in. See, help is on the way.
Old 08-21-2013, 02:04:56 PM
thanks again billy ! any idea on how to fix that ?
TIG set up for my Miller AEAD 200LE? cweaver7018 Welding Shop 2 11-13-2010 10:22:45 PM
Trying to find out what kind of onan engine is on my AEAD-200le? Need gasket kit. cweaver7018 Welding Shop 1 10-23-2010 05:47:00 PM
Miller AEAD-200LE welder-generator Lil Joe Welding Shop 2 10-17-2010 01:35:22 AM
Miller Blue star 2E OR AEAD 200LE bobgil Welding Shop 3 05-12-2010 09:31:48 PM
Miller AEAD-200LE: Engine options ASavage Onan Generators 6 11-15-2006 12:05:41 AM
